Question about Fisher Paykel EcoSmart GWL15
Good Morning/Afternoon, I have a Fisher Pakel Pride 5.5 (MW059AU). The machine fills, washes, but when it gets to the first rinse cyle it doesnt pump out (sometimes a trickle). The motor appears to work, and the cooling fan spins. It then errors and beeps with the following lights (read from left to right): Off; Off; On: Off; Off; On; Off; On;. I believe this means a Sensor Circut Fault (as advised by the FP Customer Service Team). They have quoted an unbelievable amount of money to get a tech on site. We have recently moved (although the washer was kept upright with exception on when on the trolly - slight tilt - but has worked for 4 weeks without a problem). I have had some seriously messy loads. could it be the pump or is there something else I can look at? All assistance is greatly appreciated.
  • 1 more comment
  • ange_kemp Oct 13, 2010
    Thanks fr all your help Jahn27.
    I have removed all the soggy clothes and bailed out as much as I could. I then tried to spin the machine and it worked? (this did not work with load in). I have then ran an empty load with no incident so I put on another load. But the problem occured again.
    So.. with that I have
    I have laid the machine on its front and totally removed the pump. Nothing stuck in there and have checked the one hose from pump to top of machine/exit hoses for kinks or blockages. (didnt remove hose but was able to blow rather forcefully through it.
    Sorry to ask but i cant seek to locate the diverter valve? I can see images of other models and have googled spare parts so I would know what to look for but sadly cannot find it?
    Sorry to be a pain.. (perhaps I should stick to my day job :S ).
    Any furhter assistance you can give me is greatly appreciated.
    Thanks I found it.. and cleared out some debris. Thank you so much for help. I have now done several washes.
    Brilliant. Couldnt be happier.
    President:
  • 1,554 Answers
It is fault code 37 which means pump blocked error and it appears when while draining the water level reading from the pressure sensor has not changed for over 3 minutes. Check out the drain hose and make sure it is not clogged nor kinked. Also check the pump for blockage including the diverter valve which may be stuck in the recirculation position, giving the module the appearance the pump is blocked and not lowering the water level.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 10, 2010
  • Jahn27
    Jahn27 Oct 13, 2010
    The diverter valve is the one where the drain pump and the recirculation pump inlet hoses are attached to. Its sole purpose is to divert water to the recirculation pump during washing and to the drain pump during the spin cycle.
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Dismantle washing machine fisher and paykel - unit smells -need to remove bowl to clean out
b4 u remove bowl try this 1/ buy 2 pkts bicarb of soda. 2/pour into empty bowl of unit. 3/select high water level 4/ select hot fill. 5/ start cycle 6/ let it wash for 5 to 10 mins then turn it off, do not let it get to rinse and drain the water away. leave it over nite with water still in it, in the morning restart program and let it do a normal cycle with no clothes in it. it will not refill as it already fill of water.please reply to see how u went or 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
I have a fisher & pakel eocsmart cycle but when it gets to rinse it starts beeping and wont drain the water
We had that problem and is was because we had the hose (which is long) too far into plumbing drain it would set off a syphon effect and stop. Then it would start the beeping
Oct 28, 2009 | Fisher Paykel EcoSmart GWL15
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Aug 05, 2008 | Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
585 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
