Question about Fisher and Paykel DEGX2 Dryer
How to access the right side bearing assembly
How do you change bearing on dryer drum
Posted on Oct 13, 2010
I am getting a growling noise like possibly a bad bearing from the right hand side . any suggestions
Sounds like a cam bearing but you should pull the right side cover and check your clutch assembly
Dec 23, 2014 | 2008 kawasaki Vulcan 1600 Nomad
Tip
Free, information
If you here a roaring noise in your front wheel and when you turn one way or the other and it stops. then your gonna be looking at changing your wheel bearing ( hub assembly ) , but how do you know which one to change. Well when driving down the road, move steering wheel back and forth easy, which ever way you turn the wheel and the noise stops that is which side is bad.
Example : your driving alone and you turn your wheel to the right and the noise goes away, then it's your right wheel bearing ( hub assembly ).if you turn to the left and the noise stops, then it's your left wheel bearing ( hub assembly ).
on Feb 02, 2010 | Chevrolet 1500 Cars & Trucks
96 deville new hub assembly stops rotating when tightened
are both wheels off of the ground? (shouldn't really make a difference, but you never know). Also make sure the hub assembly is sitting flush in the spindle. You might have to 'tap it in a little to seat it. And check that the abs wires aren't getting caught around the cv axle while rotating.
Dec 04, 2012 | 1996 Cadillac DeVille
2005 equinox wheel bearing assy wont come out
okay i assume the rotor is off,remove the bolts out the back, take a hammer and beat the front of the hub the top then bottom then the sides to free,hit so that hub pull out,you will be hitting the back side the hub where the wheel would sit,if that doesnt work then use a chisel to break free, stick it where the hub meet spindle,ITs just frozen beat it.a56579d.jpg
May 15, 2010 | 2005 Chevrolet Equinox
How do you get to the front wheel bearings on a 1999 toyota tacoma so that i can grease them?
For the most part it is very similar to doing a brake job, you will need to gain access to disc area. once you have removed the caliper you will need to remove the dust cap, this will allow you to remove the nut that secures the disc to the spindle. after you access to the front bearing, remove and set aside, put washer and nut back on, slide rotor out tapping it to remove rear bearing, remove nut/washer and hand pack with wheel bearing grease. re assemble, check and bleed brakes if necessary, Good Luck!
Sep 13, 2009 | 1999 Toyota Tacoma PreRunner
I hear a humming noice in the rear. What could it be and how do I fix it.
sounds like a bad wheel bearing..if drum brakes,remove drum and center cap from wheel bearing..remove center nut and pull bearing from spindle..replace hub/bearing assembly and center nut..if disc brakes,remove caliper/rotor,and hub/bearing assembly
Jun 03, 2009 | 1995 Chrysler Sebring
How do I get the clutch to release from the transmission on a evo
All 1996 Model Year and newer vehicles
equipped with manual transaxles except Accents
, which have the "push" type clutch system. SERVICE PROCEDURE:
  • Drain the transaxle gear oil.
  • The reference photo to the right shows the clutch related components as viewed from outside the transaxle case.
75c260f.jpg Loosen the release lever nut and washer
Separate the release lever by removing the snap pin and clevis pin.
Separate the release lever from the fork shaft.
Loosen the bolts attached to the release cylinder and separate the release cylinder from the transaxle assembly (no need to open the clutch hydraulic system).
  • Remove the transaxle assembly after removing each bolt attached to the engine assembly.
  • Remove the clutch cover assembly. The release bearing is still attached.
To separate the release bearing from the clutch cover, rotate the release bearing to gain access to the bearing snap ring.
Mar 28, 2009 | 2003 Hyundai Santa Fe
Front Wheel bearing removal
If it is a hub assembly you dont remove the bearing, its replaced as one piece. If the parts store sold you just the bearing you WILL NEED a press. There is no trick, you will only ruine the hub and bearing.
Feb 08, 2009 | 2004 Chevrolet Aveo
Can a shade tree mechanic change the clutch in '97 mitsubishi 3000?
Removal (3000GT AWD)
1. Remove air cleaner cover, air hoses and vacuum pipe. Remove air cleaner, intake hose, battery, battery
tray and washer tank.
2. Disconnect transaxle control cables and speedometer cable. Raise and support vehicle.
3. Remove both inner fender splash shields. Remove clutch tube bracket and disconnect clutch release
cylinder (including clutch damper assembly on FWD models) and wire aside. Support transaxle assembly
with jack and disconnect upper transaxle mount. Remove mount, bracket, plug and stoppers.
4. Remove transaxle assembly upper coupling bolts. Disconnect tie rod ends and lower arm ball joints.
Remove right support member, starter cover (if equipped) and starter.
5. Remove left side bearing bracket mounting bolts and pry left axle shaft from transaxle. Wire left axle
shaft and inner shaft assembly aside. Pry right axle shaft from transaxle and wire aside.
6. Remove front bank side and rear bank side transaxle stays. Support transaxle assembly with a
transmission jack. Remove transaxle assembly lower coupling bolts and lower transaxle from vehicle.
7. Insert a clutch alining tool to prevent pressure plate and clutch disc from falling. Loosen pressure plate
bolts gradually in a crisscross pattern to avoid warping pressure plate flange. Remove pressure plate and
clutch disc.
May 14, 2008 | 1999 Mitsubishi 3000GT
Fisher and Paykel DEGX2 Dryer Logo
98 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
