Question about GE Kitchen Ranges
I have a L44 gas stove the oven will not lignite. what might be wrong?
    Sergeant:
    Champion:
  • 351 Answers
Hi most likely the igniter is bad it is by the burner will glow when you turn oven on sometimes they glow but are still bad hope that helps you jim
Posted on Oct 11, 2010
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
How to turn on JennAir oven
turn on is ver simple.just press the power button on the front pannel it will light up. for more details please clicks this link 1 by 1 WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN
http://www.repairclinic.com/0088_13_1.asp --------------- http://www.applianceaid.com/gas.html --------------- HOW RANGES/STOVES/OVENS WORK http://www.repairclinic.com/0088_13_3.asp
Aug 30, 2009 | Kitchen Ranges
I have a Frigidaire stove, model fgf316asa, and the oven does not heat. The ignitor still glows but does not ignite the gas. I cannot hear the gas coming from the line. What's wrong?
Hi, You should change the ignitor. Even tho it glows, the ignitor is to weak to open the gas valve. UNPLUG the oven. Remove the floor panel in the oven and you sill be able to see the ignitor. This is very common with gas stoves.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | Ovens
Oven not heating
I know waht is wrong and I sell the solution.
Thanks!
email me at: roozbehani@hotmail.com, if interested.
Jan 11, 2009 | Stoves Premier 900GRa Gas Double Oven
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
