Question about HP Photosmart C6180 All-In-One InkJet Printer
What color ink cartridge does photosmart c180 take
  • 27 Answers
SOURCE: HP Photosmart 8450 Ink Level Indicator
replace the ink cartridges
Posted on May 31, 2008
  • 7 Answers
SOURCE: Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
Posted on May 27, 2009
nirikip
  • 56 Answers
SOURCE: HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
Posted on May 13, 2010
aroracaty2
  • 503 Answers
SOURCE: HP Photosmart 8250 is printing
Please follow the below mentioned steps.
Step 1: Check the ink cartridges HP cannot guarantee the quality or reliability of non-HP ink. If the ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Step 2: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale. Replace any empty print cartridges. To check ink levels, examine the ink drop icons on the color graphics display. c00368083.jpg
  • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
  • If an icon is empty, you may need to replace the corresponding cartridge soon.
  • The printer cannot read ink levels in non-HP, refilled, and remanufactured cartridges. A question mark instead of an icon displays for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
For a larger display of ink levels, click the Right Select Photos arrow. c00368084.gif 1 - Right Select Photos arrow The ink levels display in larger format, with the icons corresponding to each cartridge. Figure 1: Ink levelsc00368085.gif Step 3: Calibrate color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step 4: Clean the printhead If the steps above have not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step 5: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Oct 08, 2010
SOURCE: have a hp photosmart premium
HP Photosmart Premium C309 not printing black
Got that problem also, Black would not print but dark grey would be printed ???
What i did and it worked was reset to factory settings, unpluging the printer for ± 25 seconds
holding 3 and # for and other 25 seconds went and after pitting power back on
then re-enterring your setting, all went fine
http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C309-suddenly-stopped-printing-black-ink-any-solution/m-p/495549#M30719
Hopping this will help others
Posted on Jan 27, 2011
HP photosmart 7510 new ink cartridges are loaded but a notice is given that no cartridges have been installed.
*Remove Protective Tape
*Reset Ink Cartridge Counter
*Run Extended Cleaning Cycle
*Diagnose Refilled Cartridge Problems
*Update printer drivers
*Check Hp Photosmart 7510 Manual- https://guideusermanual.com/product-name-photosmart-7510-e-all-in-one-printer-series-c311-manual&po=243459&lang=English to proceed to further options if above are not useful.
Feb 10, 2017 | HP Photosmart 7510 C311A Inkjet...
What color and black and white cartridges should I use for a HP Photosmart 1115 printer?
It looks like your Photosmart 1115 printer uses an HP45 black ink cartridge and an HP78 tri-color cartridge. Some HP printers will accept re-manufactured ink carts, while other HP printers will not...just so you know. I've always bought genuine HP ink cartridges on eBay to save $$$.
Jun 23, 2014 | HP Photosmart 2610 All-In-One InkJet...
On HP Photosmart 7960, which cartridge to replace when the blue and green look pale
The printer takes a tri-color cartridge and a black cartridge. So anytime there is an issue with color, replace the tri-color cartridge. As far as using compatible inks, you will not be able to use HP's software for ink levels with compatible inks. This feature will work only with HP ink cartridges.
Oct 23, 2011 | HP PhotoSmart 7350 InkJet Printer
To know when ink needs rep
With compatible ink you will just have to watch for colors fading. HP software supports only HP ink, so the ink monitoring software will not function with compatible cartridges
Oct 21, 2011 | HP PhotoSmart 7960 InkJet Printer
How do i know which kind of ink cartridge will fit in my HP photosmart C4180.
Your printer uses two common ink cartridges, HP 95 (color) & HP 98 (black)
Hope that helps.
Oct 26, 2010 | HP PhotoSmart C4180 All-in-One Color...
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
Black and white printing not working
sounds like its a expired ink issue. on alot of the hp photosmart printers the ink has a expirey date on the carts the best solution would be to contact hp and chances are they will send you free carts if your ink has been expired. when a black ink is almost out most of the time it trys to draw ink from the color carts mixing to make the appropriate color.
but you can also try the following.
See the instructions for
calibrating a print cartridge in
the Care and Maintenance
section of the HP Photosmart
Printer Help.
Aug 11, 2008 | HP PhotoSmart 7960 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
298 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
