Question about Briggs & Stratton Starter 394943 490420 494990
I have craftsman 18.5 horse riding mower when i turn key its like battery does not have enough power to turn engine over,was wondering if it could be the starter cause battery is good.
trippssmengi
  • 76 Answers
SOURCE: craftsman riding mower
It should be fine as long as the snow plow is made for your model mower you also might want to look into tire chains for the rear. One thing the plow will not work good for is wet or heavy pack snow but if you keep up with the snow it sould be fine
Posted on Jan 09, 2009
SOURCE: my LT1000 craftsman riding mower will not start,
Pull the carb. and rebuild it I think you will find the unit will come to life.
Posted on Mar 25, 2009
  • 323 Answers
SOURCE: I have a 1987 craftsman riding 17 horse mower. I
Sounds like the rings are worn and letting oil escape past them into the cylinder head. After all, it's been in service a long time. There are several options, including a rebuild with boring out the cylinder and put oversize rings in, buying a new engine and replacing the old one, or just buying a new mower.
Sirwriter
Posted on May 16, 2009
  • 376 Answers
SOURCE: WONT START WITH KEY BUT WILL WITH JUMP
Check the inline fuse first. If good, disconnect the small wire plugged into the bottom of the solenoid and hook a test light to it. Lock the clutch/brake pedal down and turn the key to start. If it lights up, replace the solenoid.
Posted on May 29, 2009
woobie dog
  • 1273 Answers
SOURCE: murray 18hp 42 deck wont start
Hi.
The best advice here is to put your battery on charge, and, while it is charging, remove each connection, and clean the terminals back to "bright and shiney". The clicking noise is probably the solenoid trying to pull in to provide power to the starter. There also sounds like the comnnection to the starter needs to be removed and cleaned. If this connection is dirty or loose, it can arc and smoke without cranking. Also, if the terminals at your solenoid are corroded, the motor cannot recharge the battery on the run, and loss of power to the battery will result. Clean your connections, and try again!
This should correct your issues. In extreme conditions, it may be necessary to replace your wire from the solenoid to the starter, if it is significantly deteriorated, but I'd clean it all up first.
Best regards, --W/D--
Posted on Aug 11, 2009
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
Craftsman 42 inch riding mower Model number 917-272751 that wont turn unless I remove the spark plug.
try and jump start it direct to the starter this will test the cables and battery if no change and the starter is good then there could be a problem with the compression release on the camshaft
Jul 06, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
Mower dies when put in gear
have you checked the mower bed to see if its free to turn over,,if the bearings have sezed up or are tight this loads up the mower engine
Jul 05, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Can i replace a 17.5 hp mower engine with a 18 hp engine?
You will need to shop carefully. That is not too much of a power jump to worry about ruining axles, gears and the like. BUT, do be mindful that you have to shop an engine to match two very important criteria:
Bolt patterns and spacing: This is how the engine will attach to the mower's deck/chasis.
Output shaft length, diameter, taper and if it's keyed or non-keyed.
If looking to just replace a tired old iron horse, similar make and model to the original with slight power upgrade cannot be helped - but the bolts and shafts will be pretty much spot on.
May 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replace key assembly
any small engine repair shop should carry that switch - or sears . com - just put in your model number
Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs & Stratton Starter 394943 490420 494990 Logo
67 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
