Question about Apple Power Mac G4 Desktop
I have a G4 PowerMac Sawtooth which was given to me, it has an OWC 1 GHZ. PowerPC CPU processor board with the gold colored heatsink and single fan. It has 1GB of PC-133 RAM and the latest firmware installed and two IDE Drives, and OSX 10.5.6. But I can't use it. The G4 chimes but video never comes up unless I hold down the internal MB reset button, and then it loses the decade, year, date, time, and other info. Then video works one time until the set is shut off. I've put a new battery in, no change. I've tried five different ATI, and Radion 7500 AGP and Apple Rage II PCI cards nothing is defective, but nothing gives video after the chime. One log file stated something about a cache failure, but I never had the original G4 / 350 MHZ. CPU card to see if it is the OWC CPU board cache that is at fault. For the last year and a half it has just been sitting here while I use my older G3 / 450 MHZ with 640MB of PC-100 RAM running OSX 10.4.11 which gets slower and slower after an hour or so, until the twerling cursor just stays on continuously... What does my G4 need to function properly???
    Problem Solver:
  • 10 Answers
It is possible you have a power supply failure. My MDD was doing the same thing unless I reset the PMU. There is a tutorial here on checking the PS - D275729F-09DA-4FBB-96B3-BEEEB2C04619.html It for a MDD, but I would think it would be useful for your situation.
Do you have an Intuos tablet connected? The drivers for that might be causing the problem and should be updated to the newest driver available
Posted on May 11, 2013
2 Suggested Answers
KenKaBob
  • 89 Answers
SOURCE: ATI Rage 128 Pro ADC 16MB AGP Video Card
Hello Burnolid,
Well, yes, if you have an AGP PowerMac G4 then any AGP video card will FIT into that AGP port.... The question is to know if that card is Mac Compatible ?
Where did you get the card ? Did you get it our of another mac ? or from someone who got it out of a Mac, then yes, it should be compatible with any Mac with a AGP port.
Posted on Apr 02, 2009
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
PowerPC G4 (1.2) running slow on normal computer usage and internet surfing. CPU temp is running at 106 to 110 deg F. What can I do to speed up Machine. (512mb ram)
Hi their isnt that much you can do you need to check whats running on your computer and delete software you dont need as having this running in the background will slow it down loads, the only other option you have would be to install more ram or even a new processor.<br /><br />if you go to www.crucial.com<br />then scan your computer on their site it will then tell you how much ram you can install i use this site when im building computers.<br /><br />let me know how you get on or if you need further assistance ok<br /><br />plz rate this solution as i have a whole page of unrated posts, thanks<br /><br />
Aug 27, 2010 | PowerLogix 1.2 GHz PowerPC G4 (pfd1.2g100)...
Dear Sir sir i have hp desktiop pc and i have
You need to remove the Heatsink from the CPU and re apply heatsink compound to both the CPU and the heatsink then replace the heatsink onto the CPU. the reason for the overheating and shutdown is that the connection between the heatsink and the CPU has become "Aged" and no longer transfers the heat like it should
Jul 20, 2010 | HP Compaq d530 SFF PC Desktop
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Apr 04, 2010 | Apple MacBook Pro Laptop Computer with...
Can't see the HD on the MAC explorer. I cant access HD contents.
there is nothing to be fear.Sometimes it is not seen in explorer.
Sep 11, 2009 | OWC MercuryZ600+ G4/500-600MHz Altivec...
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
Need Mac G4 laptop schematic manuel
Not sure if you want an actual circuitry schematic, or a internal parts guide.
A manual for field-replacing just about every component inside your Powerbook can be found here.
I expect that circuitry schematics are much harder to come by, and are actually likely to be protected by trade secrets.
Apr 03, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Moniter problems
Hi, have you used the same motherboard in the two towers? sounds to me like you may have a couple of faulty capacitors on the board. Open the case and study the capacitors closely [with a magnifying glass if need be] capacitors fail very often when heated. they are the round components that sit in sets of 5, 6, or more in a row on the board. if any are bulging from the top or bottom, then its time for a new board. Regards mistyman
Sep 01, 2007 | OWC Mercury (OWCME4121330L2S) PowerPC G4,...
Apple Power Mac G4 Desktop Logo
107 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
