Question about Kenmore Dryers
My dryer wont heat up and i was wondering if it is the lightbulb that heats up the dryer
  • 171 Answers
No it is not the light bulb that heats it. It has an element inside that heats up. Before anything you need to go to your breaker box and find the breaker marked dryer and reset both sides of the breaker. What I mean by this is the breaker box that is for the power coming in to your house. It is in this panel that the breakers are for the power in your house. The dryer breaker is a double 110 volt making it a 220 volt breaker .So both of the 110 volt switches need to be reset.
Also make sure you are on a cycle on the dryer that requires heat. Try the setting that has the numbers for the amount of time you want to run it for set it to 45 minutes and leave it for five minutes and then open the dryer and see if there is any heat. If there is no heat we may have to call the repair man to come over and look at it . If it does work then your in luck so please remember to click on the yes box on you way off the web site. Thanks and Good Luck!
Posted on Oct 10, 2010
Replacing whirlpoool dryer lightbulb
You will need a buld rated for this service. Some bulbs are designed to be operated in an environment with vibration, extra heat, etc. They will last much longer than a standard bulb. Best Wishes
Sep 01, 2014 | Dryers
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
Runs but wont heat so was wondering where the 2 house fuses are located...btw already replaced igniter
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | Frigidaire GLGQ2152ES Gas Dryer
I have an electric Frigidaire dryer model #FER641CFSO, Im not getting any heat and was wondering if this could be a problem with the thermostat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Frigidaire Electric Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Only half of the heating element works
i looked up your model andfound it to need part number 3401338, this is the heater, i cannot see howe only 1/2 of the coil is going to light, its either on and all lights or its gone bad in which case its never gonna glow, its one filament like a lightbulb as long as the filament is good its alll good. too long to dry or extendedd dry times is most likely an issue with a blocked/clogged vent hose
Dec 09, 2008 | Whirlpool Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
