Question about Sharp R-303CW Convection / Microwave Oven
I have 2 Sharp R898M Convection /Microwaves , the R895 has a blank but backlit display. The R898M has a display which is very dim, although now just usable. I suspect a stock fault on the display electronics, does anyone have any idea where i should look ?
  • 3 more comments
  • mclamp Oct 11, 2010
    I FEEL THIS IS INSUFFICIENT
    I have taken out both DISPLAY boards & checked all connectors & soldered all pads on the boards (big job) I SUSPECT SOME COMPONENT HAS GONE HIGH RESISTANCE . tHIS MUST BE A STOCK FAULT ON THESE DISPLAYS, Someone must be able to pinpoint that COMPONENT, PLEASE.
  • mclamp Oct 19, 2010
    A REPLACEMENT DISPLAY IS NOT $40 IN ENGLAND BUT £95 . UNLESS SOMEONE KNOWS A SENSIBLY PRICED REPLACEMENT (THE MICROWAVE ONLY COST £100 NEW!)I HAVE TO HAVE COMPONENT LEVEL INFO TO AFFECT AN ECONOMIC REPAIR.
    Possibly but how much would one be?
  • mclamp Oct 25, 2010
    I HAVE ALREADY CHECKED THIS , THERE MUST BE A SUPPLIER CHEAPER THAN THE VALUE OF THE OVEN
  • 8,197 Answers
If the display is dim or blank you need to replace the display board. I was looking for one and they are no longer made.
Posted on Oct 25, 2010
  • 2,299 Answers
Are you looking for a new display?
Posted on Oct 19, 2010
Open up the display and push on the end of the ribbon cable where it connects to the edge of the display driver PC board, if it lights up then your ribbon cable's connection pads are failing. REplace the ribbon cable. If it DOES NOT light up then you will need to replace the entire display assembly (driver board and LCD)
Click on the link below to view the Sharp R-898M operation manual (If you have lost your manual):
http://www.sharp.eu/cps/rde/xbcr/documents/documents/om/20_mwo/R898MA_OM_GB.pdf
Posted on Oct 20, 2010
    President:
  • 1,216 Answers
Don't Worry.
its a common problem with the sharp microwaves. the control pcb needs to be replaced. it should come with the clock attached to it.
This is a control unit problem which we regularly repair nationwide for $39.95 postpaid. No need to buy a new board.
We have details and critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 11, 2010
  • 2,069 Answers
On The display module, contact has gone loose. normally, opening up unit and performing service would fix this. if not technical, then its time for service..
Regards
  • 11,896 Answers
I would replace the display. Partselect . com or daysappliance or repairclinic will have it as well as diagrams and instructions to replace it if needed.
Posted on Oct 10, 2010
  • Nate Stansfield
    Nate Stansfield Oct 11, 2010
    It is the control PCB (printed circuit board) assembly, and it contains the VFD.
    The VFD (vacuum fluorescent display as opposed to LCD, liquid crystal display) is not available as a separate part.
    You can sometimes brighten them up a little if you have some smoky dust that's gathered due to static electricity. (That's common)
    Disconnect the keypad strip.
    Next, remove the board from the control panel frame.
    Next use a soft cloth (not a paper towel) with a non-ammonia cleaner and wipe off the front of the glass VFD and the rear of the display window in the plastic frame.
    You can test the power signal to the display panel with a voltmeter. The main circuit powers the display panel. It can get faulty capacitors that control the electrical current across electronics. These capacitors can wear out through use and time. The display panel itself is also very well known to wear out and burn out through time as welll.
Is my Miele M6262 Microwave oven a convection oven?? Sounds silly but was told it was when we bought it but it doesn't seem to be?!?! Thank you
From what i can tell, it utilizes microwaves and is indeed not a convection oven. Although it does have some extra features such as a 'grill' setting, i think that is just using microwaves at a lower (or higher) power.
Sep 06, 2017 | Miele Microwave Ovens
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
Sharp jet convection double grill
Looking at other answers below your question on the page that i am viewing anyways. It appears that Sharp convection microwaves or Sharp microwaves in general seem to have an ongoing problem of that sort. The solution is to replace the main circuit board.
Nov 09, 2013 | Microwave Ovens
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
LCD pad, numbers do not appear clearly but as a distorted image. example 1:10 may appear as blank.1E example .40 may appear as blank.1L microwave works fine just the read out panel is distorted,...
On most recent Sharp microwaves, the fuse only interrupts main power, so if the fuse is blown, it will be totally dead.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes then try it.
Then chances are you have a failed microwave display. Unless this is an over the range, touch screen, or convection type, it's probably not worth repair, but you can get more information on such repairs here.
Jan 15, 2011 | Sharp R-310CW 1100 Watts Microwave Oven
SHARP MODEL R895(SL)M TURNTABLE NOT TURNING
Check turn table motor operating voltage on the motor if the voltage is normal then check motor pulley(crack or broken) ,if o.k replace motor with the same type,if the voltage is missing go to the control panel and find out any wiring problem,if everything o.k replace control panel.
Jan 15, 2011 | Sharp R-303CW Convection / Microwave Oven
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Dim Display Panel on Sharp Convection/Microwave R-1851
Mar 13, 2009 | Sharp Microwave Ovens
Sharp R-303CW Convection / Microwave Oven Logo
507 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
