I have router in my room but my wireless signal seems no signal?
    Problem Solver:
  • 13 Answers
Was this router already putting out a signal or is this a new installation type deal.
I do need to kno what brand U have to better help you fix this.
NEW INSTALATION
PLUG YO COMPUTER/LAPTOP TO THE NUMBR 1 PORT, TYPE 192.168.1.1,
GOTO WIRELESS follow instructions to get the router to start sending signal......i'm on yahoo messngr rite now if you care to elaberate more
Posted on Oct 10, 2010
  • btruitt95 Oct 10, 2010
    my yahoo id is btruitt95 subject line put router help,ok if you dont put in subject line as i state here filter will not let u connect to me... ok have great day
IPhone connects to wifi if I am close. If I go to another room the wifi falls off. Could it be my battery or something else
It could be your wireless router also. In some cases, the router's signal isn't strong enough to reach to multiple rooms.
If your photo battery seems fine, then I would begin troubleshooting the wireless router.
Hope that helps!
Jul 01, 2013 | iPhone Apps
Something is blocking wireless signal, i live in flat so in one room there is wireless router and in other room signal is very poor sometimes it's not connecting. i tryed 3 diffrent routers the last one is...
There are several likely causes, if the building has plaster walls it may have metal lath behind it blocking the signal.(this is fairly likely the cause) If there are high-power microwave transmitters within 2 or 3 km, can cause spotty interfering. Neighbors with a wireless router close to your wall can as well.
If you can move the router to a position across from the door between the rooms, you can test by connecting (wireless) your laptop near the router, then walk it into the other room (stay where you can see the router). If the laptop stays connected move across the room to a point where you did not have a signal previously, if you are still connected leave the laptop there and move the router back to its original location and recheck the laptops connection, if it is gone, it is your wall...
Apr 23, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Signal strength very low when down stairs
move the router to the room above the downstairs place of required access and this should solve your problem
transmission of good clear signal is determined by the buildings cosmetic makeup,ie wood seems to be easier for the signals to tranmit thru compared to steel and concrete
Hope thhis helps ,Cheers MISTERDJ
Apr 10, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router not powerfull enough to connect to laptop in other room
the topic states you have a G router so a g or b will connect. make sure the laptop is not higher then that eg: an n wireless adapter.
Nov 30, 2009 | NetGear / WGR614 / 54Mbps / 802.11g /...
Very short range
No this is not typical if the Network card and router are just one room away. However electrical interference and walls do impede the signal.
Try moving the Router around to see if the signal improves.
You can also adjust the antenna and pointing it in the direction of the Router.
1. Position your wireless router (or wireless access point) in a central location.
2. Move the router off the floor and away from walls and metal objects. (Such as Metal file cabinets)
3. Replace your router's antenna.
Antennas supplied with your router are designed to be omni-directional, meaning they broadcast in all directions around the router. Upgrade to a hi-gain antenna that focuses the wireless signals only one direction. You can aim the signal in the direction you need most.
4. You can add wireless repeaters. (just the room next door this would be a last resort if all else fails)
5. Change your wireless channel. You may find one that will transmit a stronger signal.
6. Reduce wireless interference
If you have cordless phones or other wireless electronics in your home, your computer might not be able to "hear" your router over the noise from the other devices.. To quite the noise, avoid wireless electronics that use the 2.4 GHz frequency. Instead, look for cordless phones that use the 5.8 Ghz or 900 MHz frequencies.
7. Update your firmware or your network adapter driver
Source:
http://www.microsoft.com/athome/setup/wirelesstips.aspx
Nice diagrams on this web page too.
(Couple items left off as these did not seem to fit your current situation)
Oct 06, 2009 | Belkin Dual-Band Wireless A+G Desktop...
Toshiba satellite l505-s6906 will only connect to a linksys g router in the same room as soon as i leave the room it disconnects
Check to make sure the lead are firmly connected to the wireless card. If they are make sure that they are reversed. Also if you have a neighbor next door that has a computer with wireless, see if it picks up your router, that way we can determine if it is a network or computer issue.
Sep 16, 2009 | Computers & Internet
Laptop and iPhones cannot connect to my network unless they are i
hi! I will be more than glad to help u in this concern..your using a wireless n router and the n router will work with the signal properly if u are using a wireless n network adapter. If you are using a wireless g adapter then u need to use a wireless n range expander in order for the other wireless g adapter to get good signal..or try buying a antena which 9 dbi which will boost the signal from your wireless g adapter..
Aug 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Airport card only works in same room as router
Do you have a cordless phone in the apartment?
how many rooms do you have and in which room is the signal low? What router do you have?
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router:
  • Router mfg'ssuggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the router may cause conflict with other routers within your network range. change the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 20, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Wireless range/signal seems very weak
ok the problem is that ur using a wireless b modem
the wireless b is the shortest of the classes of wireless routers
you should go with a G or N series
this should solve ur isse
the B series is for one room operations then the signal has to go through ur home that is more resistance on the signal
you could also buy a 2wire modem /router at best buy
that covers ur whole property with ur wireless range
but u will pay the same in one router as this 2wire single unit
Apr 11, 2009 | Gateway Wireless-B Router (wbr-100)
Wireless only works in room where router is
Get a extender at radioshack or local computer store. If your walls of your affice are concrete I would recommened that you more your wireless router out of that room and run a longer ethernet cable to help the signal out.
Feb 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
David Payne
David Payne
