Question about Maytag MDB7100AWB Dishwasher
Upper water wand does not rotate ? maytag dishwasher How can we solve this problem?
  • 11,896 Answers
Remove the wand and clean it out as well as the water inlet hose that attaches to it. Make sure you have good water pressure or it will not turn.
Posted on Oct 10, 2010
The unit is 6 years old. Dishes on the top rack do not get cleaned. Dishes on the bottom rack are fine.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | KitchenAid Dishwashers
Maytag dishwasher wands don't turn
Here is a tip about why the dishwasher arms may not be turning...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
May 22, 2010 | Maytag MDB5100 Dishwasher
The bottom washer arm does not turn or squirt water
Hi Matt.
The lower housing underneath the lower wash arm may still have something blocking the water passages.
If the spray arm is clean and it freely rotates try lightly pressing down on the wash arm and then rotate it. Your checking to see that when water is applied to the spray arm it forces the arm down against the lower housing tower and hopefully does not lock up. If it does lock up while pressing down and rotating obviously you need to find out what the cause is.
You may have to remove the lower wash arm housing and clear the debris from the water passages. Once the passages are clear it should work fine.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Viking DFUD042 Built-in Dishwasher
Soap not fully rinsed from dishes, maytag quiet series 300
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 12, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Loud noise maytag dishwasher quiet series 100
Hi All,
I have had a Maytag Quite Series 300 for some years now and have done basttle with it on may occasions. I now consider myself somewhat of a veteran, although by no means a repair expert!
Grinding Noise: From either a clogged/blocked impeller or not enough water getting to the impeller.
For a clogged impeller, it is fairly easy to disassemble the washer to get at the impeller to remove any debris or blockages.
For not enough water it can be a number of things. First of all, you will notice that the noise lessens if you add a jug or two of extra water. This is because if the water level is too low, the pump impeller will get some air mixed with the water & this is LOUD! Now for the causes:
Float – If the float gets stuck in the wrong position (debris or water deposits), it will not fill enough.
Float Set Wrong – Seems thats some of these dishwashers have the float set a little too low to let the dishwasher perform without grinding. A few pennies attached to the float with a rubber band seems to help here. Don't go too far or you'll flood your kitchen!
Timer – Some folks have mentioned that dishwashers that fill on a timer will not fill enough in the allotted time, if the water pressure is low. While this is true, I have looked over the electrical & parts diagrams for the QS300 and I do not see a timer listed anywhere. Also, the wiring diagram appears to show that this dishwasher only uses the float to achieve the correct water volume. I could be mistaken here.
Note that in VERY hard water areas (like mine – TDS of 850 hardness or 49 Grains), the plastic fins on the cover of the impeller get very choked up with water salts and this can impede flow, leading to a low-water symptom, when in fact, there is plenty of water.
Dishes Not Cleaning:
Poor Water Flow – See above, all the above items will negatively impact dish cleaning.
Poor Q uality Detergent – After trying them all – Yes, all – Do not use cheap detergent. Buy the brand names: Cascade or Electrasol work well. I have found that by far, the little packs work the best. We found that the liquid works second best and the dry stuff really isn't up to the task at all, no matter which brand.
Spray Wands Catching – We found that our lower spray wand was catching on the bottom of lower dish tray, so I very slightly bent down the legs that the wheels mount to in order to lift the dish tray/basket a little and give the wand a little more room. This worked well.
Spray Wand Nut Too Tight – The factory seems to send the dishwasher out with the nut on the bottom spray wand tightened a little too far. Loosening this a little bit lets the bottom wand rotate much more easily.
Top Spray Wand Not Meeting Receptacle – The top spray wand is attached to a pipe that mates with a port (well, one of two ports, depending on if you have the top rack in the “Upper or “Lower” position). The pipe seems to have a tendency of missing the port. A well placed elastic band will help here. Note that on our dishwasher, by the time the first elastic band wore out, the pipe had been permanently moved to the correct position by the gentle pressure.
Tines/Dish Holders On Top Rack Falling Over – The tines (metal spikes) that hold dishes on the top rack fold down by design. Issue here is that they do it sometimes during the wash, causing the dishes to fall over and block the spray. A few well placed rubber bands help here as well.
Water Salt Buildup – If you live in a very hard water area, you can still get clean dishes from yor dishwasher. We do and we have VERY hard water. Buy a gallon of vinegar once a month. Pour this into a clean dishwasher. Turn it on so that it runs for 2 minutes to circulate the vinegar. Open the door & let stand over night. Close door & finish cycle. This will cut down significantly on the hard water salt buildup in the washer.
It's A Maytag – Sorry folks, it's true. I have learned (after purchasing the dishwasher) that Maytag has run into financial difficulty in recent years and has reduced build quality to save money. If you got suckered into buying one of these, you will very likely never buy one again. My opinion is “Do not by Maytag.”
Hope this helps someone!
Dec 31, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Figidare dishwasher
It seems other posts were correct - The upper arm doesn't spin all the time. Once I learned that, and let the dishwasher cycle through, I saw that the upper arm does spin. So, there wasn't a problem with the upper arm afterall. That doesn't solve my crusty dishes problem, but that may have something to do with the soap we're using. We're going to try changing that next.
Dec 27, 2008 | Dishwashers
Won't start
It sounds like you have a food blockage or some blockage between where the water fills up and where it goes into the pump you need to take out the water wand (the rotating thing with water coming out) only the bottom one. You need to unscrew the water wand and make sure nothing is blocking in there.
If not then check your filter which should be next to the water wand remove it and then clean it and make sure nothing in in there to block water getting through.
If you have any questions please dont hesitate to ask
May 27, 2008 | Hotpoint 24 in. HDA1000Z Built-in...
Grinding noise for maytag quietseries 200 usually when it first starts up
I had the same problem with my Maytag Quiet Series 1 dishwasher until I read the comment left by the guest on June 1, 2008. I tried his suggestion about the rinse cap adjustment and WOW it WORKED. No more growling noise. Thanks you saved me a service call.
Apr 06, 2008 | Dishwashers
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Maytag MDB7100AWB Dishwasher Logo
139 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
