Question about Dryers
Wont heat element checked good so did thermal fuse and thermostadt
  • 171 Answers
AT this point you will want to check your breaker box for the house. Check to see that both side of the 220 volt breaker for the dryer are both on. What I usually do is reset them both just to be sure.
Posted on Oct 10, 2010
Dryer wont heat, replaced thermal cut off and it worked for maybe5 minutes and then it quit heating and now there is no continuity on the new thermal cutoff...I was wondering if there could be a short
The most likely cause of the thermal fuse blowing out again is either a grounded element or a clogged vent. I am assuming you have an electric dryer. If so, unplug the dryer and find the terminals to the element. Remove one of the wires to the terminals and use an ohmmeter/continuity meter to check between the chassis ground and one of the terminals on the element. You should not read any continuity. If you read a short, then the element is grounding out to the chassis. Replace the element.
If the element is okay, then the vent is probably clogged. After replacing your blown thermal fuse with a good thermal fuse, unhook the vent hose off the back of your dryer and run your dryer through a full cycle. If it doesn't blow the fuse, it's your vent and you'll need to clean it out and make sure no birds built a nest in there. If your thermal fuse still blows, replace all of your thermostats.
Oct 25, 2014 | Dryers
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
DRYER WILL NOT HEAT UP I HAVE ALREADY REPLACED ELEMENT, THERMASTAT BY ELEMENT AND THERMAL FUSE CHECKS GOOD
This is a good website and should help you fix the problem, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 18, 2010 | Roper Dryers
My dryer is working, but not heating what can I do?
assuming you have checked the outlet for 220v, it could be either your thermal fuse or the heating element itself.  if you have power and thermal fuse is good, odds are the heating element is open. you can check both the thermal fuse and heating element with an ohm meter, AFTER YOU UNPLUG IT.
Aug 04, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore 970-c82162-10 dryer is running but wont heat
check the thermal fuse located in the blower vent housing near the vent tube it checks like a fuse either good or bad,then on the element case check the hi-limit and cycling switch they also check like a switch, and the element if good will have resistance,if open it will show infinity on the meter,
Apr 11, 2010 | Dryers
Wont heat
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 06, 2010 | LG DLE7177 Dryer
Kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 28, 2009 | Dryers
Dryer will not heat but turns on and spins but no heat.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
Mar 11, 2009 | Dryers
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Mar 08, 2009 | Whirlpool Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
