Question about Targus PAWM001U Mouse
My Targus amu75us is no longer recognized by computer. Why?
What can I do I plugged in a mouse to my laptop and now my touchpad wont work
There will be a setting in the touchpad interface to allow the use of both.
Mar 17, 2014 | Targus Corded Mice AMU75US Compact Optical...
My retractable targus optical mouse keeps turning on and off when I plug it in. How do I take it apart? Model: AMU75US
The problem may be in the actual connectors. Try using a different USB port. If the mouse is out of warranty, you could snip the usb plug off and splice it into another USB connector.
Sep 27, 2013 | Targus Corded Mice AMU75US Compact Optical...
Hi, please send me driver for mouse PAUM01U. My laptop not recognizes the mouse or when recognizes malfunctions. Tanks a lot
There are no drivers oddly, I looked everywhere. I have the exact same mouse and the exact same problem that you do. None of my computers would recognize so I just assume that perhaps the mouse is broken. Every Targus product I had has been cheaply made.
Apr 15, 2011 | Targus PAUM010E Mouse
My computer is not recognizing the device...
Goto this web address and download and install the driver for either windows XP or Vista depending on what you are running.
http://www.targus.com/us/drivers_manuals.asp?SKU=ACB10US
Aug 18, 2009 | Targus (ACB10US) Bluetooth Wireless...
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Feb 25, 2008 | Targus AMW15US
Targus PAWM001U Mouse Logo
777 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
