Question about Roomba Robotic Floor Bagless Vacuum
Roomba does not do anything
I turn turn my roomba on, I push a nd select the size of the room and it plays a little tune, then the spin brush does spin for like 2 seconds and then nothing else. Please help me fix this problem. Thanks
Dianna
  • SteveHH Jun 05, 2008
    batterie is charged. turn on unit, all lights green. press room size button, the side brush goes around for about a seconde then the whole thing shuts doen
  • Anonymous Jun 20, 2008
    My Roomba has had a battery issue for some time now. I haven't used it in quite a while (months, years, I don't know for sure) because it would complain of a discharged battery after only a few minutes of cleaning. However, now when I finally tried to use it again, a new problem appeared.
    Now, it charges normally, if I plug the cord directly into the Roomba. It will not mate with the home base, however, even if I place it on the contacts manually.
    When I start it, all the buttons come on green. I then press a button to make it begin cleaning. The motor whirs up and runs for about 1 second, then it shuts down. About one second later, the power light and lights behind whichever button(s) I pressed (to give it a job) flash green then the system sits silent, and doesn't do anything else.
    My Roomba is a relatively old Roomba Discovery, if it helps.
Posted on Jun 20, 2008
  • DgtlPioner Jun 20, 2008
    Ugh, stupid thing, I didn't tell it to make that a solution... Sorry...
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Brushes on my roomba don't seem to be spinning.
Try running your roomba with the dust bin removed to see if the brushes turn. Take the brushes out and make sure they're clean. You may need to replace the brushes if they're worn. Failing that, you can find instructions on how to take your roomba apart. Take out the brush assembly and open the screws on the side of it to expose the gears that drive the brushes. There will probably be a lot of gunk in there jamming them up. You might need to check the motor too.
Sep 24, 2009 | Roomba Robotic Floor Bagless Vacuum
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
My roomba 560 has brushes that spin one rotation then stop then you hear a click and they rotate one rotation stop over and over. I took compleatly appart cleaned, lubed, and inspected all looked good?
I thought my brushes were clean, but here is what I discovered, and it fixed my Roomba.
The yellow bearing on the opposite end the brush rollers from the gearbox will pull off the shaft. These bearings spun freely and looked clean, but when I pulled them off there was hair and junk between the end of the brush and the back of the bearing. When installed in the Roomba this gook warms up and gets sticky causing friction and stopping the brush from spinning.
Use a toothpick to pull this stuff out and the brushes spin free again. I was very frustrated, and this fixed it, works like new again.
Mar 16, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
No suction
Roomba does much of its cleaning by the brush and roller on the bottom, but an important part is the little fan at the back of the debris bin which provides 100% of the 'suction.'
First, take off the vent cover on the back of the debris compartment and start Roomba on a mission. You will see the little turbine spin (if it's working) and probably a little dust cloud will come out.
It may not be working at best efficiency, however, because dirt gets sucked into the housing and blocks much of the air flow. Now that you know what the fan/turbine looks like (it's quite small, only the size of two stacked silver dollars), peer down into the larger opening of the debris bin and view the turbine from the other side. Chances are there's some crud stuck down there which is impeding air flow. (There's a hollow part of the turbine where the air is sucked into before being expelled out the back, that's probably filled with pet hair/dust/etc.) Clean that out using a long knife, chopsticks, or anything else that can reach down in there. Bang the dust bin down (lightly) to dislodge any more hair that's up there and continue cleaning until it's all gone.
I've had 3 Roomba's and they all get hair stuck up there. I only have to do this once a year or so (multi-cat and dog household here!) but it makes all the difference in the world.
May 01, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
221 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
