Question about Samsung Syncmaster 940BW LCD Monitor
Got votage supply in, but no display. - Samsung Syncmaster 940BW LCD Monitor
  • 11,361 Answers
You have to do some caps checking and voltage checking.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 10, 2010
I can't get the CD player to turn on it is called SuperSonic audio system SC-506
There are a lot of possible failures but if you own tecnical skills look at the power supply first and measure the output votages.
Nov 24, 2016 | Supersonic Audio Players & Recorders
How do l fix my cd player
check input supply socket/ check smps out put votage
Oct 08, 2016 | Audio Players & Recorders
Jandy lite 2. How do I correct an fl 5 error?
FL5 is related to input voltage. You state that the voltages check out. Service code FL5, "brown-out condition exists",
will reset after the condition has been resolved.
However, the reset may take up to 3 minutes. The LJ
controller checks the power supply voltage every 3
minutes. If the supply voltage drops below 85% of the
nominal supply voltage, the display will show the FL5
service code and the heater will not start the ignition
sequence. The controller will check the supply voltage
again 3 minutes later. If the low voltage condition still
exists the FL5 service code will remain. If the actual
supply voltage is above 85% of the nominal supply
voltage, the service code will clear automatically from
the display and the heater will resume normal operation.
If the heater was in either 'POOL' or 'SPA' mode
when the brown-out condition was detected, it will
remain in that mode when the condition is resolved.
If
the water temperature is less than the thermostat
setting, the ignition sequence will start automatically
and the heater will operate normally.
Jun 17, 2015 | Jandy Laars Lite 2 Pool Heater 175,000 BTU...
Onida tv CO21BLKTAG
Check all the components at the main power regulator section. The voltage output from it should not raise more than 109VDC.
Sep 09, 2013 | Televison & Video
Hp designjet 5500 power supply error 1
Possible that the main capacitor has leaked and so there is drop in the +B or the sub voltages. It is important to check the rail votages to the main board , remove SMPS unit an check.
see link below for tips on SMPS power supply
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
May 12, 2011 | HP DesignJet 5500PS InkJet Printer
SHARP MICROWAVE R-310AW DISPLAY GOING OUT
Remvoe the panel and see if there is any infestataion of cockroaches or insects into the display panel. if so remove and clean the bord properly using some petrol and a brush. make sure you do not damage the display or the board. Now check for any dry solder on the printed board , if bad do a touch up solder on the suspected dry points. check for the filter capacitors of the power supply and the regulators.
Check votage to the mP , solder the crystal and check.
Aug 27, 2010 | Sharp R-316FS Microwave Oven
No power on
if sb +5 is ok then check one by one these component :-
check main swithing transistor for open
check diode, capesetor and 3.3 ome resitor it may be open after then check
+ 12 to +18 volt for pwm ic and ,
if votage is not missing then change pwm ic
Apr 21, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
67 votage display on generator output.
Please stop making new problem threads each time you answer, instead post a comment to one of the 5 threads you already have open for this problem. It's getting hard to follow the conversation :-)
OK, now to the problem. You say you have checked 67 volts is displayed on the generator output, I think this means that you see 67 volts on the control panel display when the generator is running. This can be several different problems:
a) a bad CT/PT module that tells the controller the wrong voltage
b) a bad A/D module inside the controller itself
c) a bad voltage regulator
Get a real DMM meter and measure the voltages at the top side of the output (large) circuit breaker of the generator. Put the black lead of the meter on the neutral wire and then measure to each of the phase wires on the circuit breaker. If you get normal voltages then you probably have a bad A/D, if you get 67 volts on all 3 phases you have some other problem.
You still haven't told me what model/spec of generator this is, look on the data sticker on the generator cabinet.
Peace,
Carl
Dec 14, 2008 | Coleman Powermate Powermate 5000W...
Dispaly cannot read disk
DONT FORGET TO RATE SOLUTION
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER
Nov 18, 2008 | Sony PlayStation 2 Slimline Console
Open Questions:
See all Samsung Syncmaster 940BW LCD Monitor Questions
Samsung Syncmaster 940BW LCD Monitor Logo
82 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
