Question about Canon MP560 All-In-One InkJet Printer
I have a Cannon MP560 about 2 months old. It has been working fine but now when I scan or copy I get a line right down the middle of the page. If I print direct from my laptop I have no problems, only when I use the scan or copy function. This is not caused by a mark on the glass. Any ideas?
    Brigadier General:
  • 4,088 Answers
Look for a speck of debris on the scanning bar under the glass which blocks light at that point. Hope this helps!
Posted on Oct 10, 2010
Psc 1610 all in one scans with black lines down the middle
Open flat bed, remove scan camera, clean internal reflector glasses with ear buds to clean dust on it, as well as clean flat bed glass with galss cleaner both sides fix it back, check copy & scan...
Feb 01, 2012 | HP PSC 1610 All-In-One InkJet Printer
Printer works fine, but when scanning to copy or scanning to fax a line appears right down the middle of the either the outgoing fax or the printed copy. This when using the feed from the top of the...
If it only happens when you copy or fax, as opposed to 'printing"...clean the scanner glass -both the main glass and the narrow **** glass on the left side.
Please rate me.
Mar 31, 2009 | Dell 1815dn All-In-One Laser Printer
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
FAXING SAYS CANT SCAN TROUBLESHOOT ROUTING , DONT HAVE A BOOK
usually something on scan glass..ord lamp is bad..try coping blank paper..if line shows up...check glass clean and try again..
Dec 26, 2008 | Brother DCP 7010 Multifunction Laser...
Paper has dark marks down middle
If you make a copy, does the copy have dark areas down the middle of the page? If so, remove the toner cartridge and gently roll it around to redistribute the toner inside, maybe even replace the toner cartridge if you've had it a long while. If you still see unevenness, you may need to have the machine looked at.
If the copies you make on your machine look fine, then I would suspect that the person sending you the fax has a dirty scanning element. Check with them to see if they can clean the scanning element and it should improve the fax quality.
Oct 23, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Canon MP560 All-In-One InkJet Printer Logo
91 people viewed this question
old marine
old marine
