Question about Maxtor QuickView (4r080l0-qv) 80 GB Hard Drive
I installed a Maxtor 4R080L0 as a slave drive. My Windows Explorer (XP) cannot "see" the drive. - It is recognized by the BIOS. - It is properly listed in the Device Manager and 'running properly' - Win XP notifies me that new hardware is installed at startup. However it is NOT listed in the Registry under MountedDevices. It does NOT show up in Windows Explorer. I removed all entries in MountedDevices in the Registry, and let Windows rediscover all the devices. Still not found. I have removed the drive, restarted, reinstalled the drive, restarted. Still no drive showing up in Explorer How do we fix this?
    Novelist:
  • 102 Answers
You will need to go into the control panel, administrator, and then disk drive manager. once there you will need to initialize the new drive and then format the drive before the system will see it. Format using the NTFS file system only if you are using XP, After the format is completed reboot the system and your new slave drive should show up just fine and you will be able to log into it or use explorer to view it.
Posted on Apr 15, 2017
CompuGuy44
  • 432 Answers
SOURCE: Not detected by My Computer
Go into Control Panel go into 'Administrative Tools', double click 'Computer Management' click on 'Disk Management'. Do you see the hard drive?? Right click on the drive and select 'Format'. If this didn't help, write back and we'll find another way.
Posted on Jul 14, 2007
Geekinator
  • 183 Answers
SOURCE: maxtor 3200 160gb usb hard drive not in my computer
Hello kc9iid.
"Any suggestions?" ... Yes. Here's a quick few:
If it's showing in your WinXP's "Device Manager", try reinitializing it.
1. Select the device (maxtor 3200 160gb), then right-click > "Uninstall" it.
2. Reboot (instead of rebooting, you may also simply do a menubar > "Actions" > "Scan for hardware changes". However, if you haven't already rebooted since problem was recognized, this is a good time to do it now. If left un-done, you'd be amazed how often that one action alone will work wonders).
If that brings no joy, see if the drive is reflected in your "Disk Management" console [Start > Run... > type "diskmgmt.msc" (without quotes), then "OK"].
If it's not there, your registry is probably configured to "hide" (not display) the specific drive letter assigned to this drive. You can both check and correct this by getting "TweakUI". Download it here http://www.softpedia.com/get/Tweak/System-Tweak/TweakUI.shtml. After it downloads, launch it, then ensure the subject drive letter is checked ON [TweakUI > left colunm "My Computers" > "Drives"].
Good luck, and post back with a status report and/or any further questions.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 24, 2008
  • 6 Answers
SOURCE: My Maxtor One Touch III shows up in Device Manager
Hey guys I had the same problem... All the drivers for the device are inside the drive. Maxtor doesn't have any updates availble because you don't need any. What they've neglected to let any of us know is the power supply provided with the unit isn't powerful enough to run it. Replace the original power supply with another one and this will solve the problem. I replaced mine with an old laptops power supply, the fit was alittle tight but believe me it works.
Posted on Apr 25, 2009
SOURCE: Maxtor External HD - The device cannot start. (Code 10)
I had the same problem. After trying everything suggested on multiple sites, I realized that I had connected the power supply for another device to my Maxtor external drive. When I found the right pwer supply and connected it, the problem resolved.
Posted on Nov 04, 2009
jestamac188
  • 79 Answers
SOURCE: My mator storage drive is not showing up as drive
Hi the yellow warning usually means that the device has been disabled.Go back to the Device Manager and Right click on your device to see if it has been disabled,if it has re-enable it ,reboot your pc and try your device. Hope this helps you.
Regards Bill
Posted on May 17, 2010
I have a Dell Demension 3000... I have a hard drive in it that has XP as the OS... I am trying to install a second hard drive as a slave and I want to install Windows 7 on that hard drive. I wiped the 2nd...
yes it will show device is working properly
did you change jumper setting of your hard drive if not see the label top of you hard drive and change jumper to slave
Sep 11, 2010 | Maxtor Hard Drive
I have an old (1995) maxtor disk model 71626AP out of my old computer. I think I want to install it as a slave in my windows/XP desktop computer. Other than removing the jumper at J20, is there anything...
Windows will recognize it. Just be sure the other drive is jumpered as master/primary and the old drive is jumpered as slave/secondary and that they connect to the same IDE cable.
Aug 28, 2010 | Maxtor Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
My vista computer doesn't recognize my maxtor one touch 4 external harddrive...it doesn't recognize it on my xp either how can I fix this...I have a lot of stuff backed up on this and it is less than a...
HI,
What I would suggest, is to take the drive and install it as a slave drive. Make sure your pin settings on the drive are set to slave, and your main drive is set to slave. Then XP and Vista will recongize it so you can pull the data off it, then reformat the drive and see if you get any errors.
Good Luck
Mark
Oct 27, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
My maxtor drive doesn't work as a slave drive. It is recognized by bios but not by windows XP
Maybe your hardisk is not compatible with xp, was it an old hardisk? Try it with other computer if it detect.
Thanks
Nov 22, 2008 | Computers & Internet
Installing hd i found in a dvr. sony pcv-rx560 - maxtor 4R080L0 80gb hd
Hi - could you please tell me what operating system you are using so I can give you the step by step instructions. You should repartition the drive just so you're you get as much room as possible on it and it will have to be reformatted and that's it. Let me know about your your operating system and I'll be happy to give you directions. Thanks.
Jeff
Jun 03, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
Maxtor diamondmax plus 9 6y080l0
IDE AND SATA CONTROLLER PROBLEMS ON MAXTOR DRIVES.UNINSTALL CONTROLLERS AND REBOOT,DO NOT PLUG IDE DRIVE IN.THEN REBOOT AGAIN PLUG IDE DRIVE AND LOOK IN DEVICE MANAGER IF DRIVE IS RECOCNIZED CORRECTLY.(ASUS BOARD) OR INTEL CHIPSET PROBLEMS.
May 20, 2008 | Computers & Internet
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
HDD not recognized in XP Installation
if you are using it as a slave hard drive, you should be able to right click my computer, manage, then in next window double click storage, then disk management, then look for your drive, you can then look to see if its recognised, if not it will tell you that its not configured, and you should be able to right click on it and format it.
Jun 07, 2007 | Maxtor DiamondMax 10 300 GB Hard Drive
Maxtor QuickView (4r080l0-qv) 80 GB Hard Drive Logo
69 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
