Question about Golden Technologies Golden CompanioN II - 3 Wheel
Golden champion II tech support - Golden Technologies Golden CompanioN II - 3 Wheel
  • 692 Answers
1-800-624-6374 hope this helps
Posted on Oct 10, 2010
1995 chevy tahoe
PointsQuestion about Golden Technologies Companion II Travel Scooter 1995 chevy Tahoe 0000
Jul 13, 2014 | Golden Technologies Companion II Travel...
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
My scooter will not start. The headlight and horn work.
HI,
I AM A GOLDEN TECHNOLOGIES REPAIR TECH.
SEVERAL THINGS CAN BE THE PROBLEM:
1. BATTERY CHARGER CAN BE BAD
2. THROTTLE POT OR SPEED POT CAN BE BAD
3.IF THE FREE WHEEL LEVER IS NOT ENGAGED THE SCOOTER WON'T RUN
4. IF THE CHARGER CORD IS PLUGGED IN IT WON'T RUN
5. FINALLY IF ALL THOSE ITEMS ARE OK YOU HAVE A CONTROLLER PROBLEM, WHICH IS THE MOST LIKLEY PROBLEM...THATS COSTLY
YOU CAN GET HELP BY LOGGING ON TO GOLDEN TECHNOLOGIES.COM AND ENTERING YOUR AREA CODE TO GET LOCAL PROVIDERS TO HELP YOU. OR CALLING 1-800-624-6374
GOOD LUCK
TIM
Apr 27, 2011 | Golden Technologies Companion II Travel...
Brake on motor drags battery down where can i get a new or rebuilt motor
Contact Golden Tech @ 800-624-6374 and ask for tech support Then explain your problem and ask if you can get just the brake assembly or have to replace both motor and brake. Cheaper for you if you can get just the brake Hope this helps you
Apr 05, 2011 | Golden Technologies Companion II Travel...
Where can I get a Battery for My Golden Companion II Scooter and the cost?
Norman you will need 2 U1 batteries and you can purchase them from any battery warehouse type store or you can try to find an Interstate battery dealer in your area or you can get them through your Provider where you got your scooter Costs around $200.00 for both Hope this helps
Feb 17, 2011 | Golden Technologies Golden CompanioN II -...
Need replacement key for golden companion ll scooter
Julie I don't have a replacement key but if you contact Golden Tech @ 800-624-6374 or e-mail the parts dept @ parts@goldentech.com give them the serial number and they can get you a key. Now if you stuck for funds like alot of us you can purchase a on/off toggle switch for about $3.00 and replace the switch with the toggle switch. You have to take the tiller cover off to get to the old switch remove it by cutting the wires and attach the 2 wires to each pole on the toggle switch. Once you have the wires attached to the toggle switch turn it on and off to make sure it works and then insert it into the old switch hole tighten the nut to secure it to the cover and put the tiller cover back together. Good luck Hope this helps you
Sep 28, 2010 | Golden Technologies Companion II Travel...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
Nov 21, 2009 | Golden Technologies Companion II Travel...
How to dissasemble golden companion II
Companion-2 scooters. Remove seat by holding up on seat lever and picking up seat at the same time. Then remove bolt from seat post and remove seat post. Remove rear cover. Unplug and remove batteries.
Jun 29, 2009 | Golden Technologies Companion II Travel...
Golden Technologies Golden CompanioN II - 3 Wheel  Logo
195 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
