Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
I just installed my diswasher and im not getting power to the unit. It was given to me by a friend and worked fine for her. All of my connections are good and the breaker is not tripped
    Brigadier General:
  • 4,088 Answers
Are the power connections to the unit 'hard-wired' or a plug and socket connection? If a socket, try a lamp in the socket to make sure that power is present. Otherwise, the power connection junction box at the machine should be checked with a voltmeter for 115 volts AC. If ok, then there is a problem within the machine. At this point, you may need to enlist someone that can troubleshoot the wiring and switches inside. Hope this helps!
Posted on Oct 10, 2010
I had a friend install a sony aftermarket radio in my 1999 olds Alero, he made sure that all the matching wires were well connected and wrapped in Etape. When i pluged the radio in and turn the car on no...
Maybe blew up a fuse while connecting or make sure that yellow wire is getting power the one for the memory or connect both red and yellow together some times if the yellow is not getting power unit won't turn on
Sep 04, 2013 | 1999 Oldsmobile Alero
The diswasher drain connection is blocked in the new badger 5 that I just bought and installed and the dishwasher cannot drain and it runs up out of the drain line and goes out on to the counter...what am...
You are missing that the plug needs to be removed on a new disposer. All new units have this port sealed as not every install will have a diswasher...Take the unit out, and look in the hole, woopsies. Push it out with a screwdriver and a hammer. this blockage would cause the water to come out of the vacuum break on the counter.
Fortunately not a big problem to repair.
Oct 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
Amp is on but wont work...please help!!
Hello lillj2323,
OK, you say that the amp won't get your RF Punch's to pound. You do not say if you get any output at all. So let's start from the beginning.
The KAC-X542 is a multichannel amp with 2 sets of stereo outputs, 1 set of stereo outputs and 1 bridged connection for sub(s), or 2 bridged connections for sub(s).
Make sure that both 30A fuses just to the left of the power connections are good.
Check that the "ID number" is set to "0". Make sure that you have RCA inputs to both channels A and B (leftmost pairs of jacks). Your subs should be connected to the 1st (+) and 3rd (-) of each set of output terminals.
Make sure that there are no broken off plugs or pins in the jack marked "H/U Terminal" or either of the 2 jacks marked "remote".
Check that the amp is set up for 2-channel bridged. The 6 switches below the filter controls and the filter pots should initially be set:
1 - Middle position (off)
2 - Up position (on)
3 - Down position (off)
4 - Up position (mono)
5 - Down position (off)
6 - Up position (mono)
The pots should be set approximately:
LPF - minimum
HPF - maximum
Input Sensitivity - match your head unit - probably between 1 - 3
HPF - maximum
After you get the speakers working, the LPF, HPF and Input Sensitivity can be tweaked for best sound and lowest distortion.
Hope this helps.
Apr 17, 2009 | Kenwood eXcelon KAC-X542 Car Audio...
Diswasher stopped working
There is a thermal fuse on the controller that commonly goes out. If you take apart the panel, and see the computer part, there is usually a part clipped on the side with 2 wires on it. When that goes out, it acts like there is no power to the unit. Very easy and in-exspensive to replace if that's it. It's pretty common on those. Good luck
Feb 15, 2009 | Dishwashers
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Not working
Make sure the remote (rem) port is powered, if not take another look at your inputs from the head unit as sometimes we tend to forget the channels orientation of ground and positive left and right.
If all else fails, have an audio installation expert help you out, a pari of extra hands would be helpful too...
Dec 09, 2007 | Pioneer GM-X372 Car Audio Amplifier
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
53 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
