Question about Tricity Bendix AW1400W Front Load Washer
No Power at All
The machine has worked perfectly for 6 years. Suddenly with no warning it wont work at all. No lights or programmes work. I have checked the plug and the mains both are fine. I am sure that this must be something simple maybe a fuse in the machine or similar. Any help or advise greatly appreciated cheers
  • Tricity Bendix Master
  • 3,463 Answers
Probably faulty door interlock. Replace same.
Posted on Dec 12, 2008
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
6 year old front load Samsung washer seems suddenly out of balance. Leveled perfect. No load problem. Any ideas?
The tub is suspended by springs and the non rotational forces are dampened by a shock absorber. There is also something called a balancer S0058 in the diagram. After 6 years springs sag and shock absorbers can wear out, I'd start with replacing those. Get the exact model number before ordering parts; a Google search will find lots of parts sources. You may even want to call the supplier to confirm compatibility of parts.
Parts for Samsung WF337AAG XAA Tub Assy Parts
Feb 08, 2015 | Samsung WF337AA Front Load Washer
I have a Sunbeam EM6910. The machine wont power up at all. Is my circuit board likely to be fried? It is 6 years old and perhaps not worth fixing?.
could be any number of faults but at 6 years old it is not economical to fix. How much did you pay and how many coffees in that 6 years... And what else did you learn....
Do some research and get a new system.
Jul 18, 2014 | Sunbeam Cafe EM6910
Machine will not turn on. It's plugged in, and other machines are working. Just suddenly stopped turning on?
Check the power cord to make sure it is fitting snuggly. Possibly change where ti plugs into the socket. If that does not work, it would appear that your machine has reached the end of its life. Usually it is cheaper to buy new than have the broke one repaired.
Mar 22, 2014 | Toshiba DVD/Video Cassette Recorder...
Television goes blank without warning for undetermined time
Power supply board have problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | LG 32LC2D Television
Brightness and contrast increases suddenly
Check following:
1- VGA chord; is it loose or faulty?
2- Power Supply section not regulating perfectly.
3- Supply line from SMPS/Regulator power supply to EHT.
4- Brightness lines and controls (Resitance may be dry soldered or burnt)
5-Pin connection on rounded board of CRT neck may be loosed, Check it if loose than fit properly.
6- Adjust the precet for accelearting and focusing anode externaly fixed with EHT if inbuilt in EHT than only solution is to replace the EHT only.
Feb 15, 2010 | LG Computers & Internet
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Tricity Bendix AW1400W Front Load Washer Logo
119 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
