Question about VIA Sound Cards,Converts Your PC or Notebook Into a Home Theater System USB
I don't know what is my original sound card system
I format my laptop without marking down what is the sound system. The supplier had gone and did not leave me any driver cd. How can I trace back and reinstall?
  • mramige May 11, 2010
    Make/Model/Product Number/Serial Number? Any additional info would help. Check for any stickers underneath the laptop.
I downloaded a driver detector. The detector sought the driver detail, and I download relevant driver base on the model detail given by the detector.
Posted on May 31, 2008
How can i reformat my packard bell laptop without the recovery cd?
The recovery cd is just a Pre-Built Windows version that includes the drivers you need for your computer.
If you want to format your pc and lack the original recovery cd, you just need to get a Windows (or other operating system you want) installation CD/DVD, put it on your optical drive and reboot your computer.
On installation, you will be asked what you want to do: Fix or Install. Choose install and check to format your disk.
After installation, if something doesn't work, its because you don't have the needed drivers, so go to Dell's Support Page find your computer, download and install the drivers you are lacking (video card graphics, sound, etc.)
Hope it was helpful ;)
Jun 25, 2011 | Packard Bell Computers & Internet
My mobile memory card want to format. without format is cant open. but i want to save my photo. is this possible.
Not usually but have you tried if your PC can read the card, sometimes the phone can't and the PC can.
Other than that the only thing I can sugest is to try using your PC to scan and Fix the card to see if that will recover the file system.
Last resort I don't know if it is possible but maybe a file recovery program to find files on the card, get what you can off the card before you format maybe even run the program after the format also to see if you can recover even more if you do not get what you want off the card prior to the format.
Good Luck!!!
Jun 08, 2011 | Computers & Internet
How to reformat laptop
  • 1
    If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
  • 2
    If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  • 3
    If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  • May 05, 2011 | Computers & Internet
    After formatting my compaq laptop with windows xp my sound card did'nt work.ithink its gone out..how to buy new card?and how much it will cost
    dont think about buying a new soundcard until you have tried all possibities to fix the sound
    if your computer came with a motherboard disc the sound drivers could be on it
    you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
    a yellow? question mark means you need to install/update driver to do this
    right click to install driver also
    click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
    click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
    (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
    also
    click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
    if his does not fix the problem
    have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
    the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
    try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
    hope this helps
    don
    Feb 22, 2011 | Compaq Audio card Sound Card
    I have fitted an additional sound card and was using it. Afterwards my computer had to be formated and I dont have the sound card driver nor do I know its name and model so I am not able to use it. How do...
    if your computer came with a disk the sound drivers could be on it
    control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
    hope this helps
    Nov 11, 2010 | Digital Audio Labs CardDeluxe Sound Card
    My husband bought a Gateway MX6025 laptop from a friend. Before the guy gave it to my husband he went and deleted the drivers-all of them. To my understanding he did a system restore but my control panel...
    Hello !
    Here's the general support link for your laptop, from the Gateway site (copy and paste):
    http://support.gateway.com/s//Mobile/Gateway/6000Series/5376nv.shtml
    and here's the audio driver:
    http://support.gateway.com/support/drivers/getFile.asp?id=20463&dscr=Gateway%20Conexant%20Audio%20Driver%20Version:%206.14.10.0565&uid=246266801
    Select "download now" and download, run and install the audio driver.
    Hope this helps.
    Sep 28, 2009 | Gateway (4000779) Motherboard
    I formated my hasee f420s laptop and and my sound
    Hi I am Vortash first thing you need to do is identify what sound card you have built in to your lap top . Go to the manufactures site and go to support down loads and get a new sound driver from there and install it .. then rebboot the system and you should be ok or go to http://www.driverdetective.com and download your chipset and other drivers from there , note this is not a free service and you will have to pay for their service regards Vortash
    Jun 07, 2009 | Computers & Internet
    I dont have sound in my IBM laptop
    Have you reloaded the motherboard drivers for audio after formatting? If not connect to the net, visit the manufacturers web-site and download the latest sound driver for your model after having selected the OS you are using. The sound is integrated sound built in the Motherboard, hence without the correct driver it will not work..........sodeep
    May 24, 2009 | Computers & Internet
    Konica Minolta Dimage Z2 camera will not read any SD card
    hi there
    you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
    hope this helps
    beergut707
    Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
    Open Questions:
    I assume many media will be interested in your support of child abuse. To wit: http://wp.me/pYTnA-5XM To you, children are fair game. You have no facility to deal with it. So be it. Here is a sample of what you support. WORDPRESS and LAUDA FINEM This website platform supports people who abuse children. They are the Boko Haram of the internet. I'll show you why. It hosts a site called Lauda Finem (http://laudafinem.com/2014/05/26/accforum-the-wislang-clan-v-counterspin-the-karam-defamation-tort/) which fancies itself, usually wrongly, as a righter of wrongs that they, in their peculiar view of the world, need to be righted. In the process, it allows the use of pictures of innocent children to attack their parents and families. I shall explain. First, I have already made a complaint to Lauda Finem's host, Wordpress, on several occasions about this grotesquely repulsive behaviour. Wordpress, as is its wont, has ignored them, pleading the American 1st Amendment about "free speech". Too profitable not to, really. Lauda Finem, according to its own lights, "reveals" horrendous doings by many people - from the prime minister of New Zealand, the New Zealand police commissioner, the New Zealand spy agency, most of the New Zealand judiciary, and sundry business people. Some of which is good fun and probably deserved. (Some of them are hilarious.) Then it takes issue with private citizens it doesn't like. To make whatever points Lauda Finem thinks it should make, it spies on innocent families. That activity includes taking pictures of the supposed culprits and displaying them on its website. It has now stooped to also displaying pictures of their children in the context of their parents' supposed "crimes". Wordpress allows this to happen. So, where's the proof that Wordpress allows, indeed encourages, the abuse of innocent children by Lauda Finem? Well, here. Here is a picture of a perfectly innocent family that Lauda Finem has decided to weave into its tawdry tales of corruption, deceit and depravity. Taken at a science art museum, presumably by the "undercover agents" it claims to employ in Victoria and Western Australia. (Reference available, if necessary.) The next generation of Wislangs, Graeme Wislangs grandchildren and daughter in-law Bridget Wislang to be precise. Apparently computer science is a real passion, as are the family's hobbies, playing doctor Mengele, cyberstalking, terrorism and dishonesty. I am Graeme Wislang and would no doubt be perceived to have a vested interest. But my battles with Lauda Finem have nothing to do with these children or their mother, nor even their father. None of whom have any involvement in one of the websites (AccForum.org) that Lauda Finem is trying to close down. But to proceed. Here is another. Three more young girls who may be eternally ravaged by their exposure to Lauda Finem's inexhaustible desire to punish their parents (inset). But we cannot stop there. Lauda Finem didn't. (In case you have forgotten, here's the link again: - http://laudafinem.com/2014/05/26/accforum-the-wislang-clan-v-counterspin-the-karam-defamation-tort/). There are more kids who have been drawn into the Lauda Finem net in order to wreak vengeance on their parents. Sins of the father and the mother, I assume. And an innocent lamb for good measure. Which simply illustrates how far Lauda Finem will go to make its sadistic points. This poor kid (below) did not even know Lauda Finem was "onto" him. But, in the eyes of Lauda Finem, he was a hideous sinner. The people in these pictures are innocent children that Lauda Finem and Wordpress have decided to abuse on the internet in order to try to punish their parents for things Lauda Finem doesn't like. This is egregious behaviour of the worst sort that may scar these children for life. It must be stopped and the perpetrators brought to account. But then you are American. I wonder if the Washington Post and NYTimes will be so forgiving?
    Jun 03, 2014 | VIA Sound Cards,Converts Your PC or...
    Computers & Internet Logo
    Top VIA Computers & Internet Experts
    David
    David
    Tony
    Abhinandan  Patil
    Abhinandan Patil
    Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
