Question about Nokia 6120
Memory full display constantly displays "memory full" and i can't recieve sms i have deleted all data i had stored on the phone and completed a factory reset but still the same issue. help!!
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have the phone reflash to correct this issue.
Posted on Jun 03, 2008
"Something went wrong" error with Google setup new device on sprint Samsung Galaxy Note 5
Being that it's a new phone, you can safely do a factory reset. I've provided the instructions below on how to do so. Remember to remove your memory card if any is inserted:
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. Turn off the device.
  3. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
  4. When the Samsung Galaxy Note5 logo screen displays, release only the Power key
  5. When the Android logo displays, release the Volume Up and the Home key ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
  6. Press the Volume down key several times key to highlight 'wipe data / factory reset.'
  7. Press Power button to select.
  8. Press the Volume down key until 'Yes -- delete all user data' is highlighted.
  9. Press Power button to select and start the master reset.
  10. When the master reset is complete, 'Reboot system now' is highlighted.
  11. Press the Power key to restart the device.
That should fix that problem, sometimes preinstalled apps from the carrier can prevent some of the Google services from running.
Nov 13, 2016 | Samsung Cell Phones
Phone has no storage space functions not working
If you are unable to operate the phone at then the last option that you can do is to hard reset the phone, please take note that this procedure will delete everything on the phone. Please follow steps below:
When the Samsung GALAXY GRAND Prime logo screen displays, release only the Power key
Press Power key to select.
Press Power hey to select and start the master reset.
Aug 18, 2016 | Samsung Galaxy Grand Prime G530H/DS...
I have a view sonic VPAD 7 and I am locked out of my phone how do i unlock it manually:
Warning: Resetting your phone will erase your phone completely. Please do not forget to sync your personal information with computer or Google server (such as contacts and calendar).
Please press MENU on the Home screen, then tap Settings > Privacy> Factory data reset > Reset phone.
? Performing "Factory data reset" will delete all data stored on your phone, please back up your files first. To backup all of your personal information on your phone, please refer to the FAQ "How do I backup my phone"
? Your date on SD card and SIM won't be deleted.
? Your SMS and MMS will be removed. Please do a memo if you have importaant data in SMS message
Nov 29, 2014 | Cell Phones
My nokia 5220 media player will not open and displaying " not enough memory "
phone memory is full and need delete some data stored or your need to reset the phone settings or the entire phone to be able to use your phone features.
By doing this,
* go to settings > restore factory default,when ask for the code, 12345 is the default code or enter your code is changed it before. Be sure to back up necessary file because all data will be deleted and will go back to original settings.
* Also check memory card memory,erase some unused data to save more space on your other stuffs.
Best regards,
Jun 26, 2011 | Nokia 5220 XpressMusic Cellular Phone
When i play music player in 5130c-2, it gives error "not enough memory"what can i do for solve this problem...
Hello and welcome to FixYa!
Nokia 5130 c-2 phone uses phone memory as a "virtual memory" to create playlist in the music player. Almost 5MB free memory required to phone to start the music player. If the memory is not there then it shows error "not enough memory".
To resolve this issue, delete some data from phone memory or transfer it to memory card, when there will be free memory available to music player, this error will not display.
You can also easily resolve this issue after formatting the phone memory or restore your phone to "Factory Settings"
I hope this solution helps you
Thank you for using FixYa!
May 28, 2011 | Nokia 5130 Cellular Phone
I have nokia N 73..I am recieving messages but unable to open as it says memory full delete some data..whereas my memory is not at full.I hardly have any data.I am unable to open my sms's .please help
Please go into inbox and delete all previous text messages. Then sent items and delete all text messages. Also in outbox, drafts. Your settings for your text messages may only be set to recieve a certain amount of texts.
You can change this by going into messages then message settings
and then other. increase the number of saved messages to 999.
If your phone is only set to save 100, you will get memory full messages once that amount has been reached.
Hope this helps and please rate
Mar 26, 2011 | Nokia N73 Cellular Phone
Problem in sending sms in Nokia 6120 Classic:it says "memory full" need simple remedy not resotre factory setting.
This is a simple remedy. Check where your sms messages get into either in your memory card or direct into your phone memory. I think where the messages are in your inbox, sent message, outbox, saved messages, in your phone memory or Sim card memory is full and you need to delete some of the sms to stop display message full.
Hope it helps.
Good luck.
Jun 29, 2010 | Cell Phones
Problem with Nokia N72 memory
korakbc switch off your phone.after your hold keys "call button,star button and three button"hold and switch on your phone.
Mar 05, 2009 | Nokia N72 Cellular Phone
N73 phone memory full
i have that kind of problem on my n73, it alway flashes memory full and i cannot recieve any sms, i formated my n73 using the dialkey*3 procedure and after reformating it cleared my phone memory, of courese u have to back up all important data, formating your phone will erase everything.
Dec 14, 2008 | Nokia N73 Cellular Phone
Problem in fon memory
MY PHONE MEMORY IS OF 44 MB...I HAVE NOTHING IN THE PHONE MEMORY STILL IT IS SHOWING ME "MEMORY FULL DELETE SOME DATA TO RECIEVE NEW MSG'S". BCOZ OF THIS I AM NOT ABLE TO RECIEVE ANY MSGS. THERE IS A FILE NAMED LIFEBLOG.DB IN THE PHONE MEMORY WHICH IS OF 30 MB AND CANNOT BE DELETED.THERE IS NO MUSIC AND VIDEOS STORED IN THE PHONE MEMORY. IT IS TOTALLY EMPTY. PLEASE HELP....VERY WORRIED
Jun 30, 2008 | Nokia N73 Cellular Phone
Nokia 6120 Logo
97 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
