My whirlpool washer model number 110gvw9959kqo, serial number cl2413863 mother board is stuck in the jeans option at 42 minutes. I press the cancel key and also unplugging the machine but it will not shut off. I also try select a different washing cycle but it wont change. I also press and hold the stop an cancel key for 1 minute.
  • ddestiny1 Oct 10, 2010
    no result, with you solution. Jeans cycle option turn on when I press cancel key. showing 42 minutes on the display.
    President:
  • 1,554 Answers
It sounds like you are having an issue with the console itself. Perform the Console Switches and Indicators Test to determine if a key is stuck. Press the SOAK and CYCLE SIGNAL keys in the following sequence within 5 seconds while the machine is in standby: SOAK - CYCLE SIGNAL - SOAK - CYCLE SIGNAL
The 7-segment display will show "dt" to indicate the sequence is done correctly. Press START then pressing each key will cause a beep to sound and one or more LEDs corresponding to the key light up. In this manner, you will be able to determine if the console is working or if one or more keys are stuck open or shorted. Replace the console if found to be not working or unstuck if any key is found stuck or shorted.
Please make sure to accept the solution if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful and non-informative it is. Accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 11, 2010
  • 2,382 Answers
Hi, sounds more like the keypad is stuck or shorted. You can try to do a membrane test by putting it into the service mode. Have the unit on, press and hold the delicates and heavy soil key together until it shows 00 on the display. Then press the wrinkle free key. This will let you test every key on the keypad. You can toggle them off and on and see if they are responding. If they are not responding then you can assume that the keypad is your problem. At repairclinic.com you can order the part you need and if it doesn't solve the problem they will take it back no questions asked. A lot of people are not too fond of these washers because of the many issues they had with them. You would have to weigh the price of the part versus a new washer. The keypad is not hard to install. Just a ribbon that plugs into the board. You may want to try to clean the end of the ribbon with a eraser and see if that fixes the problem. Make sure the unit is unplugged before going in there.
Posted on Oct 10, 2010
My washer wont start, I can't get it to cancel or reset. I unplugged for 10 minutes and all lights are still on.
We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 14, 2017 | Whirlpool Gold GU2275XTV Builtin...
Tip
Great advice. Before I got started, I opened the washer door, and ran my hand...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a kenmore elite calypso that does not respond to most key presses, except when pressing "normal" the "whitest whites" button lites, and when you press "wool/silk", the "jeans/colors" lights, "buly...
Is the panel lock on??
Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off.
If this reset does not work - unplug for 15 minutes and re-try.
If unplugging for 15 minutes does not reset the controller -
your Main Controller board or touchpad has Failed.
Upon inspection you may have a visible sign one or the other has a burned component on it.
CLICK HERE to see the controller board.
The touchpanel is available in white, graphite, or bisque. CLICK HERE
The Touchpanel is the culprit on 95% of these machines in my experience.
I believe (hard to remember without having the machine right in front of me) there is a fuse you should check on the Motor Controller board that may have popped when the touchpad started acting up too.
Choose wisely - grasshopper - as purchasing and installing the Touch panel will equate to almost 1/2 of a new appliance with a warranty :D
Thanks for using FixYa!!
Aug 24, 2009 | Kenmore Elite 45986 Front Load Washer
Whirkpool quiet partner 3 dishwasher status stuck on clean. If I press cancel it goes into a 2 minute drain cycle, but there is no water in it. It will no reset or start....just blinks clean.
if you have a heated dry option and normal wash option push those buttons back and forth three times all the lights will come on reseting the board..
push cans. and your done
if this happens again that means you have a bad heater or bad board
Aug 21, 2009 | Whirlpool Dishwashers
Control door lock light stuck 'on'
Unplug it for 40 minutes to reset.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Hi I have a whirlpool duet front load washer (GHW9100lW1) and the status is stuck on CONTROL LOCKED and i can't change it and the machine is no longer working.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Dec 17, 2008 | Whirlpool Washing Machines
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
Jeans stuck in washer
Harkins...you model looks like a one piece agitator according to the model number. Pop the cap off the agitator, you will see a bolt under there. Using a socket wrench remove the bolt and the agitator will lift up. If you have a fab dispensor on top, just pop it off. Catriver...post back.
Sep 12, 2006 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
