Question about Bosch KGU34124 Bottom Freezer Refrigerator
I have a E-Nr KGU40121 which needs the control panel replacing. How easy is it to replace as I live 2 hours from the city. Can I order one and do it my self?
SE error on Samsung SMH9151B. Where so I find the assembly part to order?
"SE" error means you have a shorted membrane keypad.
The full model number from the tag on the oven should be one of these:
SMH9151B/XAA (service manual)
SMH9151B/XAC (service manual)
SMH9151BE/XAA (service manual)
I've included the service manual link for each one for your convenience. They'll help you with disassembly and in getting part numbers.
You can order parts by entering part numbers or your full model number from the tag on the oven here.
There are three ways you can fix this, with the last probably being the best:
1. Replace the membrane keypad ("switch membrane"). The cheapest way but the hardest. If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
2. Replace the control panel frame assembly ("assy control panel"), which comes with a new keypad on it already. Pretty easy, not expensive.
3. Replace the entire controller ("assy control box"). Very easy, and usually not much more than option 2.
No matter which option you prefer, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
May 23, 2011 | Microwave Ovens
The Light has gone out in my KitchenAid Microwave Model KEMC308KSS0...how do I replace it?
I have a kems308...very similar to yours. Order the bulb by finding it on the parts list and ordering it on Amazon or thru Kaid. Mine was $13.00! The bulb on mine is a baseless bulb that goes in a bulb holder held by a spring behind the control panel. The control panel is easy to remove, but turn off the power first. Plan on an hour. If you can access yours this way it saves having to remove the whole unit.
Apr 08, 2011 | KitchenAid Architect Series KEMC308KSS...
Is it easy to replace the keypanel of the GE
Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Jul 24, 2009 | GE Profile JKP56 Electric Double Oven
We have lost the remote control to our aiwa home thater system.
heres link for replacement remote:
http://www.replacementremotes.com/STORE/prodthumbs.cfm?categoryid=7
Feb 10, 2009 | Aiwa Audio Players & Recorders
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch KGU34124 Bottom Freezer Refrigerator Logo
29 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
