Question about GE Ovens
GE oven model JKP14M - has power - can turn on to 400 degrees by the display, but nothing happens. The elements do not turn on bake or broil. Can it be a power relay on the display board? Help!!
  • 8 more comments
  • bob_hentz Oct 11, 2010
    Rylee,
    The oven temp probe read 1106 ohms. I would take it as being OK and not out of range.
    Oven relays, K-1 thru k-4. K-1 is line break, K-2 Bake, K-3 Broil and K-4 door lock.
    I am thinking K-1 relay is bad. Is there a way to check this relay with power off and is this the one that you were talking about.
    Bob
    Rylee,
    out of range.
    K-4 door lock.
    Bob
    Rylee,
    I have looked at the relays, do they unplug or will I have to purchase a new circuit board? I have taken the covers off the relays and sprayed them with electronic contact cleaner.
    I could not make the come loose, seemed as if they are soldered to the PC board.
    Thanks,
    Bob
    The Clock is working just fine, timer, and the unit will show bake or broil at what ever temp you display on the oven. Just the oven elements do not turn on.
    In the old days of points on a car, you could take 1500 grit sandpaper or a new dollar bill and run across the contact points to clean them up or to make better contact.
    I am wondering, is the relay coil bad, or just the contacts. What is the voltage going to the relay? So I can check with power on and probe the relay connection points.
    At this point, I have nothing to loose, if it does not work, I have to buy a new board, if GE still makes the part. They are bad about obsoleting parts and no replacement available.
    Bob
    I am going to find out how much a FSP Part for this unit will be. GE has discontinued the part. Also look into relay clean up and see if that helps ( it is a very long shot )
    Bob
    G E no longer support replacement parts for this oven.
    I understand there is a company in Texas that rebuilds control boards. Do you know of any other suppliers?
    Bob
    Power circuit board bad. Not available from G.E.
    Adrian at Baytron Ltd. can rebuild unit for around $90. He is located in Henrico, Virginia.
    Core Solutions wanted $179.00 for the same repair. He is a small one man shop.
    G. E. wanted $350.00 for a new board when it was available.
    Thought this might help someone else.
    Bob Hentz
  • bob_hentz Oct 12, 2010
    Each of the relays made contact except K-1. THe mylar cover was light brown and the other relays covers were white.
    The power up relay is bad.
    Board replacement - R
  • bob_hentz Oct 13, 2010
    No display errors,
    Have had some in the past ---F-1, shut the oven off and reset display and it would go away.
    The display panel is being sent off for rebuild and return.
    I will let you know of the results from this repair.
    Bob
  • bob_hentz Oct 14, 2010
    You are correct, G E no longer supports their product with parts.
    The board has been sent to R & R unit for refurbishment. Only choice out there, or buy a new unit.
  • GE Master
  • 1,711 Answers
From all your comment respond we figure out that you have already identify the problem is the PC board and you suspect one of the relay. You are correct.
The relays on their side they have their data primary Voltage for the coil (in your case is either 12V) the control voltage contacts - 120V and the maximum load in amps.
Since you have nothing to loose by the use of a soldering gun, unsolder the relays pins one by one and at the same time pull it out from the other side. In this way you can remove the relay. Try not to leave the soldering gun too much time on the board since will overheat the other electronic parts.
Now with relay on hand you can visit an electronic parts store and they will be able to give you a replacement. Now by using a pin and the soldering gun you can clean the small holes on PC board so to insert the new relay. Solder it back again and you have a new board.
Our advice is since you will make all this procedure you can remove all relays from the board and replace them all since all are in bad condition after all these years and they will probably have problem in the short future. Take some photos thaw since you might forget where each one was and the photo will help you.
You may not have a previous experience with above procedure but from what we understand you fill that you can do it and above all you have nothing to loose and many to gain. Just remember that 90 % of faulty pc board they are just having only one relay that is stuck or burn.
Try it and let us know.
Posted on Oct 12, 2010
  • 857 Answers
Pull out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. It should work . Bypassed the thermal fuse and used the oven, order a new thermal fuse if required.
Posted on Oct 11, 2010
  • 2,069 Answers
That is a control board problem. are you getting any errors on the display? post for a followup
  • Muzahura Frank Oct 14, 2010
    You should purchase a new control board.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be an oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Relay that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 10, 2010
  • 1 more comment
  • Rylee Smith
    Rylee Smith Oct 11, 2010
    Sorry for replying late, just checked you mail. Yes you are right the complete board should be replaced.
  • Rylee Smith
    When the probe is fine then it is always recommended to replace the board completely just to avoid any further issues. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Rylee
  • Rylee Smith
    Rylee Smith Oct 14, 2010
    F1 error itself states that the board is bad and should be replaced.
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
Oven will not heat.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jun 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
GE oven will bake but not broil
I trhink more than likely you have a faulty element, you need to test wether you have power to the element with a voltage tester or meter
Nov 22, 2008 | Ovens
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
Broilers suddenly stopped working
gerrie824 look at the elements and see if there is cracks in them. If so then yes they failed. During bake the broil elements come on in 1/2 power to brown the top of what you are baking. If there isn't a break in the elements, then the issue could be a burnt wire, failed relay, or such.
Feb 02, 2008 | GE JKP45 Electric Double Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Nov 25, 2007 | GE JRS04 Electric Single Oven
Ovens Logo
63 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
