Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The top drawer intermitantly makes the drawer opening noise
When the top drawer is closed it intermitantly makes the drawer opening noise (the noise that the drawer usually makes when you open it). The drawer is completly closed and nothing is in its way. Please help. Thankyou.
  • gorilladan Jun 01, 2008
    The problem has gone .away after running the dishwasher a couple of times. If it happens again I will try your suggestion straight away. It seems like it would work. Thankyou.
  • gorilladan Jun 02, 2008
    The problem came back again so I tried your suggestion and it worked. Thankyou so much.
  • 413 Answers
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
Posted on Jun 01, 2008
Monogram DISP480DXASS jack hammer noise behind the Climate Control Drawer.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
Mar 04, 2016 | Refrigerators
Screaming noise
spray the drawer with pam
Apr 06, 2014 | Kenmore Refrigerators
Top dishdrawer won't open no power
The most logical explanation is the controller in top drawer has packed up or the power board located at the base of dishwasher housing (under bottom drawer) has partially packed up and stopped supplying power to the top drawer controller. But another explanation is that the thermal relay in the top drawer (located inside the heater element assembly has cut off. This stops power to the controller. This is the most expensive to fix as the entire heater element assembly has to be replaced as the thermal relay is not separately accessible. How you want to isolate the problem and fix it depends on how comfortable you are with fixing electrical and electronic systems. This is a very sofisticated dishwasher and a small mistake is irreversible. By the way you can open the drawer by forcing it open but keep in mind not to try to shut it firmly again until you restore the controller power. Otherwise the lid seal or actuator motors will be damaged. Whatever you do, make sure the mains power is turned off if you work on the dishwasher circuits.
Feb 16, 2014 | Dishwashers
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
Home theatre (panasonic SA-PT460) drive wont open makes some noise when i press the open/close button as its closing. I unscrewed the device and removed the dvd tray from its case as i pressed the...
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
If anyone has a solution I would be grateful.
Sep 08, 2011 | Panasonic SA-PT460
Getting message Top Drawer Open-will not print
the sensor that allows the printer to know when the drawer is open or closed could be broken. You may need to have your printer looked at by a technician or if you can locate the sensor either remove it or see if it has come out of place.
Jun 04, 2010 | HP DeskJet 5652 InkJet Printer
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
143 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
