Question about Indesit W 123 Front Load Washer
Indesit washeing machine
Hi I have an indesit WIL 1435 and the prob is that thats is not washing clothes properly. Ive tried changing washin powder and thats not the prob. It seems to go through the full cycle ok but think its washing everything at too low a temp.
Please help
Lisa
  • Geofie May 31, 2008
    Dear Lisa, I purchased the same machine a while ago and found that you have to make sure your washing machine is on the right temp and cycle for it to wash properly, its very easy not to read the book but some of the settings vary depending on what your washing. Also my husband and myself made the mistake of not taking out a screw from the drum which made the machine not wash properly. I hope this helps you resolve the problem as these machines are very different to top loaders. Regards Karen.
    President:
  • 1,294 Answers
Karen, that was nice.........
Posted on May 31, 2008
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
When I took out my white shirts (35% cotton & 65% polyester) I found they were dirtier than before and clothes were still wet.. my machine is Indesit WIA121. Any solutions?
The tablet washing powder is not the best, it takes higher temperatures to fully dissolve and they are more caustic than normal powder, You may also need to try cleaning the inside of your machine, you can either use about 1/8 cup dishwasher powder on a hot wash or you can buy specific de-scalers for washing machines.
Mar 04, 2012 | Washing Machines
Indesit WIL 153 Door Lock
Hi John, did you ever fix your washing machine door as I have exactly the same problemw ith mine
Feb 20, 2010 | Washing Machines
The washing machine doesn't recognize its washining programs. I have to reset I suppose but how? Indesit w123
u select any program then turn off by the wall then you turn on and select another and turnoff by the wall wait 10 mins then turn on select the program you want and will work, theres another link on the internet somewhere ive seen it.
Nov 29, 2009 | Indesit W 123 Front Load Washer
Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Sep 04, 2008 | Indesit W 123 Front Load Washer
Clothes smell after wash cleaned filter still clothes smell
set the machine off on a 95c wash with no clothes or soap in, the most likely cause is a build up of soap scum on the inside of the drum, also try to alternate between washing powders and liquid tablets.
hope this helps
Jul 25, 2008 | Indesit Washing Machines
Wahing machine kitchenaid won't completely drain water
Check drain pump for any blockage.Pump accessible by removing lower panel,on bottom front of machine.Also try liquid instead of wash powder,and make sure that you are using automatic powder as other will foam in machine.
Apr 01, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
402 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
