Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Need help pairing a headset that was paired to another phone
  • 1,527 Answers
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue.
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use. hope it works
regards
shaun
Posted on Oct 11, 2010
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
I have nokia 6120 classic with BH-100 ear piece, how do you get the hands free ear piece to work
just go into the settings & there you will Accessory settings..
Thank you
May 21, 2008 | Cell Phones
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps...
Oct 29, 2010 | Mizco Radio Communications
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Mar 03, 2009 | Nokia Bluetooth Headset Headset
Pairing LG VX8700 with Motorola H700
try to power cycle the cellphone by turning it off and remove battery, then reinstall and turn it back on
For headset pairing
How to pair the phone with a Bluetooth™ headset The phone identifies and maintains up to 16 devices which are displayed in a list. To add a new device or pair a headset via bluetooth, turn Bluetooth™ on in both devices.
  1. Put headset in pairing mode. See Headset User Guide for more information, if needed.
  2. Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
  3. Choose [TURN ON] , press "Select"
  4. Choose [MY DEVICES], press "Select"
  5. Choose [NEW DEVICE], press "Select"
  6. Choose the headset to be paired and press ' Select '
  7. Enter the pass key '0000', press "Ok"
Link for headset setting, just choose the headset model
http://www.sonyericsson.com/cws/support/products/pairinginstructions/w300i?cc=us&lc=en
If you are using a different device the just set the Bluetooth to on on it as well
Apr 22, 2008 | Motorola Mobility H700 Headset
Tried paring Motorola BT H700 to my phone when it has already been paired to another phone
With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 05, 2008 | Motorola Mobility H700 Wireless Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
155 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
