Question about Nakamichi MB-70 6-Disc CD Changer
When I load a regular cd it says that it can't read disc and don't recognize a factory recorded cd
    Problem Solver:
  • 8 Answers
Bin the damn shitzer
Posted on Oct 10, 2010
Why is my recorder reading disc as data disc
you can only record on disks that are specifically marked for 'digital audio' you cannot just use any blank cd-r disk
Aug 04, 2014 | Sony RCD-W500C 5-Disc CD Recorder
It will not play, record or recognize any disk
Can it play regular movie disc's ? Try to use a DVD/CD lens cleaner to make sure that the lens is not dirty. They are easily available at any computer or music store. Do you have a factory reset option in the menu, try to reset the device.
Mar 03, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Does the unit recognize 80 minute discs?
Any desk CD recorder will only recognize discs labeled "Audio Disc".
That means you cannot use CD-R or CD-RW discs, that are basically data discs. No matter duration, if your 80 minute disc is CD-R or CD-RW, your unit will not recognize it. Good Luck.
Flavio/BRAZIL
Jul 25, 2010 | Philips CDR778 2-Disc CD Recorder
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Satellite A205 help "loading DVD"
Have you tried other discs? Does it read CD or recognize blank discs? Have you tried a bootable disc to see if it reads prior to Windows loading?
If the drive doesn't appear in My Computer this is a possible fix:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 19, 2008 | Toshiba Computers & Internet
Replace Tascam DP-01FX/CD -- the CD R/W won't work
I don't think there is a problem with your CD writer.  You have not inserted the type of disc your write drive requires.  You must use a BLANK "AUDIO CD-R".   Check your instruction manual concerning the type of disc required.  Data CD-R's will not work in this type of drive.  if the disc has "DATA CD-R" or "700"mb or "800mb" printed on it it will not work.  audio CD-R's are not as common and are a bit more costly.   They are the only type of disc that will RECORD in your drive.  Regular audio CDs should play in your drive.  I hope this solution will work for you and I wish you every success! Michael Mittelsdorf
Nov 03, 2008 | Tascam DP01 All-In-One Recording Package...
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Nakamichi MB-70 6-Disc CD Changer Logo
54 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Michael Galve
Michael Galve
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
