Question about Abit nForce2 NF7-S2 Motherboard
CAN'T MAKE THE SATA RAID 0 OF ABIT NF7-S2 WORKS. WHEN I TURN IT ON AT BIOS, THE PC STAYS BOOTING ON A LOOP
  • 238 Answers
SOURCE: Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Posted on Dec 17, 2007
  • 2692 Answers
SOURCE: ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Posted on Jan 05, 2009
  • 41 Answers
SOURCE: i need download drives of motherboard abit nf7-s2
Here is a link to a driver download:
http://members.driverguide.com/driver/detail.php?action=download&driverid=1270049
Posted on Jun 23, 2009
Bfsas1
  • 258 Answers
yes driver for your motherboard type are here, im glad to help, just click on link below and scroll down centre of this website enter the code on the screen into the box and hit download button under that to download the driver, welcome-
link
  • 256 Answers
SOURCE: my pc crashed and hase not posted after it crashed
Lucky1484
I am sorry but I have to point out that somehow you did misread the situation. If a computer crashes, after that it is DEAD and NO ACTION will ever come out of it. Your suggestions are valid, but only if the computer came back up. Our client has to check the power supply, starting with the AC plug and checking all the voltages. Tell him to KEEP HANDS OFF THE MOTHERBOARD!It seems that all our clients have falleen in love with the Mother Board and they are liable to have the MB "fried", or damaged beyond the point of repair. They are in love so much with the MB that they give us its number instead the computer information. We help them repair their computer!!!!
I am working to obtain a photo. I have no reason not to do it, but my wife is in charge of the camera, so, I will go to a passport place tomorrow and get it done.
Good luck to us..... CONSTANTIN (arzconst)
Posted on Jul 09, 2009
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
Hi. i have abit motherboard nf7 s2. i bought 2
Did you make sure to install the memory starting from DIMM3? You should install into DIMM3 then DIMM2 according to the NF7 manual.
Mar 14, 2010 | Abit nForce2 NF7-S2 Motherboard
I need download drives of motherboard abit nf7-s2
Jun 23, 2009 | Abit NF7-S V2 Motherboard
NF7-S2 No POST on startup. Can Not get into Bios
In that case the motherboard itself is faulty replace it..
Jun 08, 2009 | Abit nForce2 NF7-S2 Motherboard
SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Feb 15, 2009 | Intel Motherboard
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Sata 2
did you go into the bios and enable the sata for the hard drive and does the bios detect the hard drive by name and size
Feb 17, 2008 | Abit nForce2 NF7-S2 Motherboard
Abit NF7-S Nvidia2 Failed to Boot
Try swapping the power supply and as Nitro says also check the cable and connector from the power switch to the mainboard.
Jan 12, 2008 | Abit nForce2 NF7-S2 Motherboard
Installing windows xp with 2 new sata wd 150g 10k 16m raptors to NO avail...
I guess you are trying to install Windows XP in RAID 0 configuration. If so, you need to do several steps:
1. Configure the bios to work as RAID 0
2. Download the RAID driver from the mobo vendor site, copy it onto a floppy disk and have it ready for when Windows asks for it.
See this link for detailed example http://www.duxcw.com/digest/Howto/mb/abit/kx7-333/raid1.htm
In SATA there is no master/slave configuration, so there is no need for jumpers.
I hope this answers your question.
Dec 26, 2007 | Western Digital (WD1500ADFD) 150 GB Hard...
Abit nForce2 NF7-S2 Motherboard Logo
43 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
