Question about Dell Dimension 4600 PC Desktop
Transfering data from one desktop to another
I am switching from a Dell Dimension 4600 desktop to an XPS 530 desktop. How do I transfer the data from the Dimension to the XPS? Do I need any additional hardware or software to do the transfer? What is the easiest way to transfer data?
Thanks,
Amy
  • 242 Answers
If a slot is connector and the hard drive connector types are the same (otherwise you'd need an adapter), you could plug the hard drive from your Dimension in the XPS as a slave disk. This way you get the highest transfer speed.
You could then transfer the data to the primary disk of your XPS.
If you have a network (LAN) available, you could transfer your data that way. Another way is to transfer your data to an external hard-disk and then to the XPS. Of course you cannot transfer installed applications. Since they must be reinstalled on the new computer, you'll need the installer for each application.
For these methods of transferring you won't need any software. You can just use windows explorer.
Posted on May 31, 2008
    Genius:
  • 2,785 Answers
Sol 1 you can burn your data in dvd or cd
sol 2 you can transfer your data in thumb drive (pen drive)
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Dell Dimension 4600 audio
Hello download the driver here:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600
The c model:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600c
Here could be several versions of the driver so you just have to try.
Good luck
Dec 24, 2011 | Dell Dimension 4600 PC Desktop
Soundcard for dell 4600
There are 4 different versions sound card drivers for this Dell Dimension model (4600).
Go to 4600 and select Audio then download which version from the list for your desktop.
Till next time, take care of your desktop.
Feb 07, 2010 | Dell Dimension 4600 PC Desktop
Seeking a diagram of what all the inputs on the rear of the 4600 are...duh
This Link below will take you to an online service manual for the Dell Dimension 4600. Click Here
Mar 14, 2009 | Dell Dimension 4600 PC Desktop
Computer best to buy
go for a DELL XPS 1330 laptop
or get any DELL XPS desktop
you can get details on www.dell.com
and if you are in UNITED STATES
call 1-800-999-3355(DELL SALES)
Jun 06, 2008 | Dell Dimension 4600 PC Desktop
Transfering my outlook and emails folders from my old desk to my new acer desk top
No because outlook is an installed program in your older computer so you can't transfer install programs from one hard drive to the next.
Sorry
RCF
May 31, 2008 | Dell Dimension 4600 PC Desktop
Transfering data from one desktop to another through LAN connection
you have to put the cable in the ethernet card (or network card) it looks like telephone connector ( it will be big in size)
Transfer data from Dinension hard drive to XPS hard drive
If you have no experience with this, it might be easier to just copy the data from your Dimension to a external usb harddisk and then to the XPS. But i will try to explain it.
I've looked a bit around: your XPS hard drive is a SATA drive, while your the drive in your Dimension is probably a PATA-drive (just connection types. Look at the hard drives and compare them with this image to see which types they are.)
As far as I know the XPS 530 has a Foxconn G33M-S motherboard, which contains one ATA (PATA) connector. So you should be able to just connect the hard drive from your Dimension into the XPS.
To make it work properly, you should set the drive from the Dimension to slave. This can be done by setting the jumpers next to the cable connector. The jumper setting depends on your hard drive model. Usually the possible settings are shown on the hard drive.
If you feel uncomfortable with this whole thing, you could ask someone, who has some experience and who you trust to do it for you, or just use an external usb hard disk
Make sure the computers are off and disconnected from the power outlet, when you open the case...
Dell offers a user manual for your Dimension and XPS. Maybe it's of some help by removing and placing the various parts...
Please tell me how it worked out.
As you probably understand, I can't take any responsibiity for damage to your system...
If you have any problems, just post them here!
Dell Dimension 4600 PC Desktop Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
