Question about Whirlpool MT1110SKQ 1100 Watts Microwave Oven
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it) Is the microwave unusable or just need to clean the plate of the charred substance? TIA !
  • 1,606 Answers
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Posted on Oct 10, 2010
My Bosch Micro HMB405 started sparking/arcing with a burning smell. I had an empty plate in there. Was trying to warm a clear glass dinner plate. Did I kill the magnatron by putting an empty plate in the...
Michelle,
You may have killed the magnetron but you may not have either. If you can take that cover plate off, you may find that there is grease build up behind it and that needs to be cleaned off. Grease can build up there without you even realizing it and after a while it can catch fire from the heat created by the magnetron. You should never put any empty plate or container in a microwave because the magnetron needs to have something for the waves to hit. Hope this helps.
Mar 25, 2015 | Bosch Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
My microwave arcs every time I try to heat something. The silver colored plate on the interior right side of the cabinet appears to be burned. What happened and can it be fixed?
This arcing is caused by food splatter when something 'popped' or 'exploded' during an earlier cooking cycle. The food particle remained and every time the microwave gets used, this particle continues to cook until it turns into carbon. This can be as small as the tip of a pin. Carbon reacts very violently to RF energy (which is what causes the food to heat). You need to carefully remove the "waveguide cover". Clean it and check for a burned spot. You also need to inspect the inside of the "waveguide" once the cover is off. Clean it also. Make sure there is no grease or other foreign matter inside there and be sure not to leave anything in there (paper towel piece, etc..). If any of the paint inside the waveguide is burned, and if it can't be sanded off and touched up with catalytic paint, you need a new microwave oven. If the burned area is limited to the waveguide cover and you can't find a replacement, you can buy a sheet of mica material from a parts house and use the old cover as a template to make a new one. Also, "If you are on Gilligan's Island" and can't get any new material, you can cut the burned spot out and cover the hole on both sides of the waveguide cover with cellophane tape. Do this at your own risk but usually it works fine.......
Nov 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 15, 2010 | Whirlpool MH6141XK Microwave Oven
Does not cook even . put 2 items in cooker one well done other one half,
were both items the same density? Was one maybe thawed more that the other? A microwave cooks by rapidly heating the water molecules within the product that you are heating. If you heat two of the same product, it should cook them both evenly, however say you put in a frozen hamburger and a thawed hamburger, the frozen one will only begin to defrost while the thawed one will actually cook
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
There is sparking from a small metallic plate mounted on the right side of our sharp R-508HS microwave, along with an ugly humming noise. this plate is adjacent to the magnetron grille. i had heated a...
Sparking in a M/wave is a problem as it can damage the works. Not sure what the plate is you speak of, Generally all metal objects are painted with enamel to prevent sparks. The humming is a worry though as it indicates something not functioning correctly in the Magnatron which is a large transformer like object. M/waves are not as expensive as they once were and can be picked up second hand under warranty from cash exchange places for about $30 onwards. I recognise that even that is an expense you dont want, but to continue to try and use a sparking MW is dangerous and is often not worth the money you spend on repair, against a used or refurbished one with a warranty.
Sorry I cant come and take a look for you ( I am in Australia) and help you out any further. But my advice is if you cant fix it yourself easily, Ditch it and replace it with a used one.
Sep 24, 2009 | Sharp R-508HS Microwave Oven
Sparks in microwave/convection oven
Remove the plate and clean it with warm water
Jun 22, 2009 | Panasonic Microwave Ovens
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8102SS - Sparks and No Heat
The magnetron tube which makes the microwaves is behind that cover plate, and it has gone bad. It is a replaceable part, but it's not worth the cost. Part and labor would be more than a new oven. It's time to treat yourself to a new oven.
Nov 03, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Whirlpool MT1110SKQ 1100 Watts Microwave Oven Logo
242 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
