Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
There is alot of "crud" left on the top rack dishes. i have cleaned the dishwasher and replaced the hose that goes from the back of the machine to the top rack to the top spray arm - still have problems
  • KitchenAid Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 11, 2010
Can't figure out why top rack of dishes are coated with flakes of debris. Have used vinegar, dishwasher cleaner to no avail. Also has a weird smell coming from steam vent when washing a load. I even...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 10, 2011 | Dishwashers
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Top rack dishes not getting clean
When the dishes on the top rack are not getting clean the most common problem is that the water supply hose in the rear of the top rack is misaligned. With the rack empty, pull out the rack and look in the rear where the supply hose slides into the water supply. Often a plastic clip or two has come apart. Realign everything and it will work fine. If you need a diagram go to sears direct parts where they have an excellent website. Enter your model number and you will be able to see a schematic showing each part and how they go together. Joe
please rate my answer as very helpful. thank you.
Apr 04, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
5 yr old GE Adora -- have it repaired or replace?
look in the back and make sure the drain hose is about 18 ins high if the hose falls it will not hold the water in the machine
Feb 10, 2010 | GE Adora GHDA656LSS Stainless Steel...
Dishwasher repair - Bosch
Can you remove the upper spray arm (is yours under the upper rack?)-mine unscrews and then you have to wiggle it off. Run faucet water into the arm; sometimes little bits of crud get stuck in the holes that spray the water out, and this prevents a complete rinse. I just had to clear these holes myself due to same problem (I might have a different machine, though). You can do the same for the lower arm.
Jan 25, 2009 | Dishwashers
Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Top dishes not getting clean
OPEN THE DISH WASHER AND PULL OUT THE TOP RACK AND SPAY IT OUT WITH AN OUT SIDE WATER HOSE BECASE IT GET CLOG SOME TIME
May 05, 2008 | Kelvinator MDB121RF Dishwasher
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
60 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
