Question about Compaq Presario M2000 Notebook
How to repair CD/DVD drive which unable to eject
    Brigadier General:
  • 10,406 Answers
Take a Norwegian paper-clip, and straighten one end.
Insert that end into the small hole in the face-plate of the drive.
Push until you feel resistance.
Then, push another 1/8 inch (3 mm),
and the drive-tray should "unlock",
and you can manually & gently open the tray,
and remove any disk.
Then, take your computer to a qualified technician,
to get them to disassemble your computer,
remove the malfunctioning disk-drive,
sell you a new drive,
install the new disk-drive,
reassemble your computer,
and test it.
Posted on Oct 10, 2010
Why won't DVD player open?
Search Results
    How to Fix a DVD or CD Player That Won't Open - YouTube
    ? 4:53
    https://www.youtube.com/watch?v=RcVn9NUtq0c
    Sep 22, 2014 - Uploaded by doityourselfstan
    How to Fix a DVD or CD Player That Won't Open ... Up next. How to repair a CD/DVD drive that won't ...
    How to fix a DVD drive's tray that doesn't open or eject ...
    ? 9:45
    https://www.youtube.com/watch?v=Kl1jB9MJXsE
    Jul 5, 2010 - Uploaded by lowendguru
    This video shows how to fix the tray of a CD or DVD drive when it does not eject ... I have a phillips cd-rom drive and it won't open, I checked the belt and its tight, so I .... Dvd Player Sticking Door Repair And Lens Cleaning.
    How To Fix A Broken DVD Player - YouTube
Dec 08, 2015 | Samsung Televison & Video
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
Cd drive wont eject
Try ejecting it through "My Computer". Right click on the drive and select "eject". If you can't locate the drive, then it's probably missing the driver.
Nov 25, 2010 | Sony VAIO VGN-NS240E/W Notebook
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Hello
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Andrea
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
I have hopefully just burned my first photo CD but am unable to get the disc out of the slot. I have pressed just the eject button but don't know what else to do - and yes I AM blonde!
Hi, LOL!!
Ok, if you can't eject the disk double right click on computer, where you see you CD/DVD drive right click on the icon and select eject from the list.
If it still won't eject get yourself a large paper clip and straighten it, look very closely at the eject button on the CD/DVD drive, you will see a very small hole. Push the straightened paper clip inside that hole and manually eject the disk.
Post back if you need anymore help.
Good luck.
Aug 20, 2009 | Dell Studio 15 Laptop
CD problem
there must be a hole near to eject button..insert pin into it and it wl eject automatically...
Feb 01, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Toshiba Satellite M45-S359 Laptop CD/DVD drive keeps ejecting!
pull your driver from laptop ther eis 1 lock open it.
and if problem still then your lense has some problem u have to clean it or give for replace or repair shop
Jan 03, 2009 | Computers & Internet
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Compaq Presario M2000 Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
