Question about Fisher and Paykel Dryers
Dryer light burned out and broke off base of blub, had friend pull out the base with pliers and shorted the light socket without unpluging the machine! dryer will not turn-on or operate! what should i do with the dryer> Fisher & Paykel clothes dryer: Model>DEO5
  • 4 more comments
  • Kelly Lowrance Oct 10, 2010
    breaker did trip! and i reset the breaker, still not working
  • Kelly Lowrance Oct 11, 2010
    If I replace the bulb will it make a full circuit. I'm thinking that it might be more serious! I've been looking over the wire diagram and it's tied into the door switch, and there is a PC board that runs the machine. I'm looking to find a shorted board or wire fused together. It's also tied into the main motor and the start switch! Can you help me narrow my search? Can I make a simple repair, or am I looking at a costly service?
    http://i1081.photobucket.com/albums/j353...
    There is power going to the dryer! Dryer doent turn on at all, no lights! There's power.
  • Kelly Lowrance Oct 12, 2010
    I'm getting 240volts, 120 apiece for two breakers, power is getting to the dryer!
  • Kelly Lowrance Oct 14, 2010
    So I replaced the bulb and the drum lights up but the dryer still doesn't run. Have you been able to look at the wire diagram? Should I test the motor swich?
    President:
  • 1,554 Answers
The first thing to check the is the circuit breaker for the dryer. It must have tripped due to the short circuit and needs to be reset.
Posted on Oct 10, 2010
  • 5 more comments
  • Jahn27
    Jahn27 Oct 11, 2010
    Verify if the drum light turns on when the door is opened.
  • Jahn27
    Jahn27 Oct 11, 2010
    The bulb is not an essential part of the circuit. It's sole purpose is get the inside of the drum illuminated when the door is opened. With or without the bulb, the dryer will work if no other problem is present. Replacing the bulb will not make the problem more serious but will help determine if power is really getting into the dryer. Please post a photo or screen shot of the electrical diagram for me to analyze and determine where might the problem is. You can post the photo here or other photo sharing sites for a higher resolution.
  • Jahn27
    Jahn27 Oct 11, 2010
    Verify if there's power getting into the dryer. Check the voltages directly at the terminal block where the power cord connects to.
  • Jahn27
    Jahn27 Oct 11, 2010
    There's power going to the dryer but it is not getting into it as indicated by the drum light not turning on. It is likely that the power plug is fused or the door switch is damaged during the short circuit. Check the continuity of the power and/or access the door switch and join together the wires connected to it. If joining the wires together makes the drum light turn on and/or the dryer work then the door switch is indeed damaged, replace it.
  • Jahn27
    Jahn27 Oct 12, 2010
    Check voltages directly at the terminal block where the power cord connects into the dryer. The drum light should turn on when the door is opened if power is indeed getting into the dryer.
  • Jahn27
    Jahn27 Oct 12, 2010
  • Jahn27
    Jahn27 Oct 14, 2010
    Yes, I saw the diagram that's why I advised yo to replace the bulb.
    Now that power is confirmed getting into the dryer, the next thing to verify is the timer motor. You should hear the motor run if it's running. A faint buzz coming from the timer assembly indicates the timer motor is running. If not, then it must be damaged. If yes, then check the continuity/resistance of the motor windings, the motor overload protector is likely blown. An open continuity/resistance reading tells you if that is the case.
Lite bulb broke.
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Jan 08, 2013 | Frigidaire PLMV168 Microwave Oven
Cant get light out of socket it broke off
PLEASE unplug the oven first, and always unplug it when inserting or removing light bulbs.
Otherwise, or a surge can occur that damages the control circuit board. More info here.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a tiny bit.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulb broke in oven it is a general electric over the stove type the bulb metal part is stuck in socket
First of all, always unplug the oven before removing or installing light bulbs.
Before I install a new bulb, I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get the lights replaced, if you find that they still won;t come on (or if they're stuck on or stuck on bright or dim) then oyu will need to have your circuit board repaired.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 30, 2010 | GE Spacemaker JVM1740 Microwave Oven
Burned out bulb on GE spacemaker micro
You should check your light sockets for a short, to, before you put in new bulbs.
Once you have the new bulbs in, the cooktop lights still may not work.
We see (and repair) this a lot. This problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 30, 2009 | GE Profile Spacemaker Over-the-Range...
The light bulb in top of refrigerator broke, can't get it unscrewed using potato method. also tried to bend the base with a screwdriver then turn using needlenose pliers. It won't budge. What else can I...
This is where you are going to have to get ruff. Be sure the refigerator is UNPLUGGED. Grab one side of the base of the bulb with your pliers and rotate counter clockwise. Only way to get it out. Short of taking the whole light bulb assy out of the unit. More then likely got a little rust on the base of bulb and just enough to make it stick. Once it breaks loose you are home free. ken
Jan 03, 2009 | Refrigerators
Bulb broke away from its screw base in oven
Please unplug the oven's power cord first!
This is pretty common and can be a pain. It's sometimes tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
Dec 19, 2008 | Kenmore 63672 Convection/Microwave Oven
Ge Eterna Model Em0300 HBB01 under neath light
Please unplug the oven first!
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
Once you get new bulbs in it, please let me know if you the lights are still not working. This is usually a problem on the control board that can be easily repaired.
Sep 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
WE have a GE Spacesaver Microwave installed July 2005. I have tried to replace burned out nite lite bulb. Both bulbs broke from socket as I tried to unscrew. Bulb base will not unscrew. How do I get the...
First be sure the oven is unplugged whenever you are removing or installing light bulbs.
Once you get new bulbs in, if they don't work, that's circuit board damage which we repair for $39.95 for customers nationwide and you can feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
Aug 01, 2008 | Microwave Ovens
Broken Light Bulb
Unplug the refrigerator first.
Then, try removing carefully the base of the socket with a pair of long-nose plier.
Dec 10, 2007 | Refrigerators
Open Questions:
Dryers Logo
181 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
