Question about HP Office Equipment & Supplies
Colour Laserjet 2600n has problem shown in its manual as "Vertical streaks or bands appear on the page" and the remedy is "Replace any low print cartridges". A printout of Supplies Status Page shows that no cartridge has reached Low Level having only printed 412 total pages with estimated pages remaining as - BLACK=793. YELLOW=836. CYAN=483 MAGENTA=546. Automatic Cleaning has been done.
  • 2 more comments
  • Blasketto Jun 02, 2008
    Problem unsolved
    problem still unsolved after carrying out your suggestions.
    Problem is described, along with a solution, in the H.P. Manual, but it only suggests replacing cartridges. As all cartridge show that they are not low and have printed only 412 pages, there is estimated a further 546 pages of toner remaining.
  • Blasketto Jun 03, 2008
    My lack of experience doed not allow me to dismantle cartridges. Doing so would void the warranty. Would you please tell me how to do "Manual Drum Cleaning" other than cleaning the exterior (which I have already done)?
  • 59 Answers
OK, I talked to my friend who is an HP Tech and he said that there are only a few things to try. All of which are in your manual. First restore the factory defaults. If that don't work, Recalibrate the printer. If that don't work you have a faulty ink cartridge. Hope this helps
To restore the factory-set defaults
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
(SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and
then press (SELECT).
The device automatically restarts.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be
performed from the control panel using the following steps:
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then
press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then
press (SELECT). Calibrate color will display on the control panel.
3. Press (SELECT).
4. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then
press (SELECT).
5. Press (SELECT) to start the calibration.
Posted on May 31, 2008
    President:
  • 1,257 Answers
You can use the link below to solve your 2600n printer problem
error and solution for 2600n
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00314875
You have not provided any exact error you are getting .please tell something more if the above link does not solve your problem..
Good Luck !
dilipbagdi
    Brigadier General:
  • 6,966 Answers
Try removing each of the cartridges and vigorously shake. It is possible that the powder inside has formed into blocks, partially solidified, gummed together. This is specially true if the ambient temperature is usually cold and the printer is seldom used.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 31, 2008
    or you can try not so gentle taps on the cartridge to loosen things up inside (toner).
  • Louie  Role
    Louie Role Jun 02, 2008
    have you tried manual drum(s) cleaning?
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
I have a red streak on the page coming from my hp color laser Juest 2600n
are you sure the colour is not magenta,if so replace the magenta toner
May 15, 2010 | HP Color LaserJet 2600n Printer
Leaves streaks vertically on paper changed cartridge still there. 2600n printer
when you open the front of the print you will see the streaks on the black transfer sheet.
Close the front door half way or until all the cartridge doors open.
You will see the same streaks on the problem cartridge(s) as on the transfer sheet.
Change that particular cartridge, let the printer recalibrate, and presto streaks are gone.
Feb 13, 2010 | HP Color LaserJet 2600n Printer
HP 2600n prints black streaks on a page
Could be a few things but black cartridge is most common cause, they are not "cleanable" one just replaces them, if you carts are non gen HP then that will surely be your problem, slight chance could be transfer belt assy or fuser. they are also just a case of replacing, go for cart, replace it and see.
Dec 05, 2007 | HP Color LaserJet 2600n Printer
76 people viewed this question
Ben Johnson
