Question about Pentair Minimax NT Heater
My Pentair Minimax NT heater constantly displays "HI" on the LED readout, and never turns on to heat. As I understand the HI readout, it is an overtemp protection. I looked at the product manual and there is a 115 deg and second 150 deg hi limit thermostat. I assume one or both of these are my problem. Is there a way to determine which thermostat I should replace, or should I just replace both? Or could my problem be something else?
  • 990 Answers
This could be high limits but more than likely this is a water flow problem. Check to be sure your by-pass is closed or nearly closed. If this is good then you need to remove the water manifold from the side of the heater. Inside you will find another by-pass assembly and you will need to replace this.
Before doing this you can take the wires from the limit switches one at a time and use a jumper wire to by-pass them. This won't tell you if they are bad though just if they are kicking off. If the water in the heater is that hot they are just doing their job.
Sort of a catch 22 but the best I can do from here. Hope this helps, good luck.
Posted on Oct 11, 2010
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Mar 20, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
270 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
