Question about Beverage-Air 74 cu. ft. / 2095 liter Commercial Freezer PF74-GHD
What do I do?
I bought a used freezer ( E series 3 doors) and plugged it in.  It is not getting cold.  Is there any switch or anything.  The light comes on and it gets to 55 degrees after a few hours of running.  The fan seems to be running smooth.   Is There a thermastate control?
  • 828 Answers
There is a thermostat control but your problem sounds like a system that is low on refrigerant charge. If it cools down to 55°F the compressor is working. If the system is low on refrigerant it has a leak which must be found and repaired before it is operated.
Posted on Jun 01, 2008
Why does the light flicker when door is opened. The freezer seems to be working at this time.
It could be the button door switch that controls the light, or that a florescent lamp is being used in the cold fridge,
Oct 30, 2015 | Frigidaire Freezers
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
Frigadaire temp light will not go off but still cold
Do not know if you mean the cavity light or the power indicator light at the outside bottom of the door. The power light is always on when there is power to the unit. it could be red or green. The light switch could be shorted closed or open depening on the MFG design. Rare but can happen, ground short through light wiring. Access / remove light switch, remove one of the wires. If the light goes out...the switch is bad. If possible and you have a multimeter and know how to use it. Remove both switch wires and with unit unplugged measure resistance to ground. open - zero through load L1, continuity through neutral. Plugged in 120v between load L1 & ground, zero volts between Neutral & ground. Keep bulb in receptical. Call qualified tech is not sure how to use tools to test.
Mar 28, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The "door ajar" alarm keeps going off and the door is sealed shut?
Your door switch may be bad. Is the light on when you open the door when you manually push in on the switch does the light go off? On most fzr the door ajar alarm is set off by the door switch showing the door is open.Turn off the power by unplugging the fzr then you can pop the switch out with a flat blade screw driver if it is only a two wire you can use a paper clip to connect the two wires wrap them with elect tape Then plug the freezer back in and see if the problem clears if it does order a door switch. Some units use a vacume sensor but i believe all kenmores use the door switch. good luck
Aug 17, 2010 | Kenmore Freezers
Have a 3 door commercial freezer that
might be the overload relay
Jul 20, 2010 | Freezers
Aquired 3 door victory in existing bldg. Service
First check for bunrt wires that can be grounded, then you can disconnect the compressor and plug the freezer and if doesn't blow the breaker , the compressor is bad ,if still blows them ,put the compressor back and try the fan , then try the other fan(inside one) or also could be the light switch, or the defrost heaters.
Oct 06, 2009 | Victory Freezer Refrigeration ''Value''...
Freezer not getting cold
Alissa,
Try placing two or three jugs of water in the freezer and wait 36 hrs. before opening.. If the water is frozen solid you have no problems.. if its not frozen, the call a service tech..
Jun 22, 2017 | GE 16.7 cu. ft. / 473 liter Upright...
3-door undercounter refrigertor worktop surface
the coils that deliver the cold air are building up condensation. anything that gets cold in the outside should be insulated so as to reduce condensation. hope this helps
Sep 15, 2009 | Everest Refrigeration Freezers
The motor runns but the freezer does not get cold
clean your evaporator and condenser coils thoroughly and then you may need to have unit freon cheched
Jul 26, 2009 | Freezers
Haier HUF138PA-Freezer not freezing
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
Jan 10, 2009 | Haier 20.5 cu. ft. / 580 liter Upright...
Beverage-Air 74 cu. ft. / 2095 liter Commercial Freezer PF74-GHD Logo
124 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Michael Youngman
Michael Youngman
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
