Question about HP 530 Notebook PC
I cannot get the "@" on this keyboard - HP 530 Notebook PC
  • 1,428 Answers
Try Shift + 2 or Shift + "
Good luck.
Posted on Oct 10, 2010
Testimonial: "thx much works like a charmm"
    Scholar:
  • 34 Answers
You can also use the on-screen Keyboard. It's seems like a HUGE hassle, but you might be able to get a 'shortcut' key or create a "@" where you can easily copy and paste it when needed.
PROBABLY DIRTY UNDER THE KEYBOARD. Try cleaning/turning upside down and gently shaking. Mini-vac.
Also, check out Wiki How-To on Cleaning A Keyboard (and a bunch of similar topics)
Posted on Nov 08, 2010
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Which is an function key in keyboard
(FuNction key) A keyboard key that works like a shift key to activate a second function on a dual-purpose key. Commonly found on laptop keyboards, the Fn key is often used to control hardware functions such as screen brightness and speaker volume. The Fn key may also be found on extra small keyboards for desktop computers, typically for Page Up and Page Down, which are combined with Up Arrow and Down Arrow. See function key.
Feb 24, 2011 | Samsung Pleomax PKB-700B Keyboard
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
My keyboard is jammed. other keyboard can be
Any PC keyboard can be used either wired r wireless, the choice is yours.
Dec 11, 2009 | Adesso EZ-9930 (ez9930) Keyboard
My sons hp keyboard will not work
Hello janene hi, you can check your son's HP keyboard, by testing the keyboard on another computer, just make sure the PC is off when you swap the keyboard, if the keyboard malfunction, replace the keyboard with a new one, we don't usually repair the keyboard, after market keyboards are available cheap.
Nov 21, 2009 | HP DC170B Keyboard
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
My desktop doesn't recognize my keyboard
Try a different keyboard on your computer.
If that works, try your keyboard on a different computer.
If it fails, then replace the keyboard.
Sep 10, 2009 | Gateway 2520915 Keyboard
Cursor jumps around when typing. It will go anywhere in the document. Happens in all programs.
What type of keyboard you are using (PS/2 or USB)? Is that a regular keyboard or multimedia keyboard? You need to isolate the problem. Please follow the steps below.
If you are using a USB keyboard:
1. Connect the keyboard into different USB ports of the computer.
2. Connect the keyboard into different computer.
3. Try using different keyboard to see if the problem will persist.
If that is a wireless keyboard:
1. Try replacing the battery
2. Connect the receiver into different USB ports.
Check the keyboard settings:
1. Go to the Control Panel > Keyboard
2. Adjust the keyboard settings and speed.
Hope it helps and have a great day!
Jun 16, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Jun 02, 2009 | HP DC170B Keyboard
HP 530 Notebook PC Logo
97 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
