Question about Dualit 20084 2Slice Toaster
My power cord has exposed wires. Where can I purchase a replacement? Thank you
  • 1,606 Answers
The easiest way is simply go to a hardware store or even a home building/renovation center or a appliance repair shop. You can buy a replacement cord for just a few dollars compared to about $45 for one from the manufacturer. If you don;t mind you can just get some black electricians tape and wrap a piece separately around each wire, then a piece around all of that. Doesn't look as nice but for a few cents of tape which is the easiest to get/find it should works as well.
Posted on Oct 10, 2010
Testimonial: "wow - fast and easy! Thank you for your prompt response!"
How do i replace the end of an electrical cord that has been cut off
Purchase a new 3 conductor End - Note*** Connection procedure will be the same for either the Female or Male end...
  • Carefully cut around the sheathing being mindful to not cut into the individual wires sheathing.
  • Then peel away about 1.5", exposing 3 individual wires
  • Now, strip back about .50" of sheathing from each wire
  • Twist bare wires so individual strands are tight
  • Separate the cord end (many different varieties) and insert wires into a hole, securing nut, etc, to bring into proximity of connection lugs.
    • Black wire onto 'Gold' screw
    • White wire onto 'Silver' screw
    • Green wire onto 'Green' screw
  • Reattach in reverse order
May 30, 2015 | Generic 50ft 163 300 Volt Extention...
Hoover U5465-900 Power Cord Replacement
hello,
Please checck out the following link for finding the manual of ur device!!...Im sure you can find a manual there!..
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Please post back for how things turned or for further assistance..Thank you!!...
Regards!!!...
Jul 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I need replacement power cord
Well, if the power cord isn't hard wired to the TV, then the two most likely options are either a figure 8 cord or an IEC cord.
Here's a figure 8 at monoprice
3ft 18AWG Figure 8 Shape AC Power Cord Cable Polarized 7 1 15P Black...
Here's the IEC cord at monoprice 10ft 16AWG Power Cord Cable 3 Conductor PC Power Connector Socket C13 5...
Sep 05, 2014 | Coby LEDTV2326 23 TV
Electric cord chipped power shorting, how do we fix it
You will need a wire stripper, solder, solder flux, heat shrink tubing, a heat gun (hair dryer will do) and a soldering iron.
1. Cut the cord where the chip is.
2. Strip the wire on both sides by about 1/8". You should have 4 exposed wires from the two wires inside the cord.
3. Apply some soldering flux to the exposed end.
4. Heat the exposed wires and apply solder. This is call tinning and will help when you are attaching the wires.
5. Cut the heat shrink tube about 1/2" long, you will need two. Insert the heat shrink tube to both wires that is to be soldered.
6. Solder the wires together by applying heat and attaching the wires when the solder melt.
7. move the heat shrink over the soldered area and use a heat gun to heat the tube. It will shrink and provide insulation as well.
**If you don't have soldering experience, you might want to take it to an experienced technician. Bad solder or poor insulation can cause expose wires and poses an electric shock hazard!
Jul 09, 2014 | BonJour Power 1800 Grill And Griddle...
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
I don't see a power cord - does it need to be hard wired?
Many appliances do not come with a power cord. This leaves the option to the consumer to either hard wire to a terminal box, or purchase and install a power cord. You can purchase a three-prong power cord from any major hardware store. Power tool replacement cords work best, because they handle current well and have thick insulation to prevent chaffing. A good 15 to 20 amp cord is recommended. Whether you hard wire, or add a power cord that you can simply plug in, the wires as terminated as follows (U.S. Standard):
WHITE - NEUTRAL
BLACK - HOT (120VAC)
GREEN - Ground - terminate to ground lug
If you have any questions, please post back and let me know. I hope this helps you.
Apr 11, 2011 | Dishwashers
I am missing half the electrical cord on my LA-2921 6 gal compressor. How do I replace the power cord to the 3 exposed wires?
Pig tails are available thru Lowes in various wire gauges and lengths. Remove cover to pressure switch and notice wiring and replace with new cord (9 to 12 feet will work great). If your pressure switch is inside the cover and you do not want to bother with complicated procedure; just install a male plug on short remaining cord and just buy a 12 foot 14 guage cord. Good holidays
Dec 15, 2010 | Porter Cable Air Tools & Compressors
How do I replace the pull cord? do you have a manual that shows the 'guts' of the blower so I can replace it myself? Thank you Kathleen
If the unit is a canister, you will have to take the plastic cover completely off exposing the motor and cord reel. The cord reel will come out by gently pulling right side away from the left of the casing. from there the two wires from the cord reel are attached to the PCB board by wire nuts you will find tucked next to motor.
If unit is upright with cord reel you will find the situation to be really similar to the canister, but you will have to remove a few more screws to get the casing off this one.
Nov 17, 2010 | Vacuums
I have a Kenmore Diswasher model. 587.15103801 - My question is - can I wire a 3 prong power cord to it? If so, what do I need to purchase? Thanks
The dishwasher SHOULD have a three prong cord, or be hardwired using using a 3 conductor electrical wire capable of handing 15 to 20 amps (12 or 10 gauge wire). If you desire to use a cord with a plug on the end, you can purchase a power tool replacment cord rated at 15 amps or higher from the hardware store (I have found power tool replacement cords to be very durable). Make sure you purchase one that is long enough the accomodate pulling the dishwasher out from under the counter, if required. The power cord is installed in a junction box behind the lower toe panel that's located directly below the door. The wire color coding is as follows:
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
Match the color wires with the wires inside the dishwasher junction box and twist together using wire lugs. Attach the ground wire to the appropriate ground lug.
If you have questions, please let me know. I hope this helps you.
Aug 27, 2009 | Dishwashers
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Dualit 20084 2Slice Toaster Logo
203 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
