Question about Garden
My hedge cutter smokes - Garden
  • 43,501 Answers
Your hedge cutter is toast....motors run on smoke and when the smoke comes out they no longer run....:-)
Given that a hedge cutter is not all that much money to replace... trying to repair it will not be worth it...
Your best bet is to just get a new one...
heatman101
Posted on Oct 10, 2010
The tip of blade will not come together or close.
if it is a hedge trimmer as per the catagory, get a new cutter bar or get a new hedge trimmer
probably from blunt cutters that tried to cut too thick branches
if it is secateurs then do as ray suggests
Oct 02, 2015 | Garden
In need of manual kawasaki hedge cutter
try the piratebay
its a utorrent thing. type in like kawasaki hedge cutter kht600d manual
Mar 13, 2012 | kawasaki Kht600d Gas Hedge Clipper Trimmer
I have an 8104 type 7 black and decker hedge trimmer. It freezes up durning the cutting or just squeezing the trigger. Makes a loud buzzing noise. Almost like it is jammed and there is nothing jammed in...
Did you ever oil the cutters since you have owned it? Try this spray some PB Blaster on the cutters let it soak and then try running it. If you can't find that stuff just try some motor oil, pour it on let it soak and give it a whirl. Good Luck...
Aug 24, 2011 | Black & Decker Decker Ht018 18" 26...
Can i replace my cord for my hedge cutters
YES
You need the same quality cable and you need to dismantle the cutter to get to the mains connection.
If you are not up to all this then get a garden repair place to do it for you - SAFETY FIRST
Mar 10, 2011 | Garden
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Motor stopped working (apparently burned out) when hedge cutter was used to cut through some thickish branches- is this worth repairing or should I just buy another one.
If it's truly smoked, than in some cases it might be cheaper to just by a new one. The motor could be close to the same price as a new trimmer but check out websites or maybe even ebay do a little research first.
Aug 13, 2010 | Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
