Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
TV loses video and sound
Your description of this problem to another poster describes my issue exactly and I described this to the Philips Customer Service support folks even describing what I thought to be a heat problem, they offered no assistance. Questions - 1) is this a fairly easy fix, I have some technical experience with electronics?; 2) do you know where I can get a service manual to help with this fix?; 3) where can I purchase these parts?
Thanks
  • 138 Answers
Check the firmware on the set and if is is not BX23U-1.5.0.0_03531 go to www.usasupport.com to down load the currect version. That should fix the problem. If it does not your small signal board need to be replace.
Posted on Aug 20, 2008
Sound goes up and down - when its at a low point I can here a voice describing the actors movements as though it were a description for the blind - can this be deactivated?
Look in your TV menu for a 'Descriptive Video' feature, and disable that feature.
Does this happen on all video or specific input? (ie. DVD, Cable TV, BlueRay, etc.)
Dec 17, 2014 | Televison & Video
When you turn tv on it just makes a clicking sound its a phillips model 60pp920217f
If the front panel indicator lights, you are getting power to your TV. The symptom you describe suggests the power supply has failed
Jan 04, 2013 | Philips TV Tuner Video Capture PCI Card -...
Saeed
Please re-submit your problem with more details to describe what is the issue. Thank you.
May 28, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Please describe your Philips Saa7131e Tv Tuner Driver Free Downloads problem:
Problem with the Operating Systems Please describe your Philips Saa7131e Tv...
Dec 19, 2010 | Computers & Internet
Not working
If u r using RF signels (single pin cable connection), u r supposed to change some settings like palB, palD, or to other format depending on which place u r living while tuning the channels.
Jun 21, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Marantz PV5580W (aka Philips 5580) IC Analog problem? There is no red...
I have the exact same tv with the exact same problem. Did you figure out how to fix it?
Sep 14, 2008 | Televison & Video
CONNECTING DVD/VCR TO CABLE BOX & TV ETC
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Feb 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Sound and picture
Check that you have connected the component video lead to the correct sockets in both the TV and the HTS9800W.
There are two sets of Phono (cinch) connectors, which are grouped together.
Red / Green / Blue - Component connectors - video only
Red / White / Yellow - Stereo audio and composite video connectors - audio and vide
If you have inadvertently connected the red audio connector to the red component input on the TV, it would cause similar symptoms as you describe.
Jan 13, 2008 | Philips Cineos HTS9800W System
Stray voltage
Whats a F connector please??
If you can describe it more then maybe the following may assist....
There are several types of plugs and sockets on TV receivers for many applications....A SCART type has many pins for the sound and Video outputs to various type of CD, Video, or surround sound systems, or games consoles.
There are also systems that supply a DC voltage over these various type of plugs and sockets to "drive" the input electronics at the far end of the TV receiver....A classic example is for a mast head amplifier which needs a DC voltage to make the Amplifier work and this is done over the TV areial connection so maybe this is what you are describing....More detail please...
Cheers YUBEUT...
Nov 18, 2006 | Philips Magnavox TS3260C 32" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
