Question about ViewSonic Q22WB 22" LCD Monitor
Hi, I got a Q22wb -& it has a black screen .checked all capacitors-all looks ok !any suggestion as to what else to look for! tks in advance.
  • 11,361 Answers
Caps have completely fat tops for sure? Check the ECR of the caps?
You will need to do the voltage checking on those DC filter caps.
Please read my guide.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Oct 10, 2010
Testimonial: "tks for your answer ,will go back & double ck everything, caps do look ok. but will follow your guide & re ck. tks"
How do I fix my Visio tv when the screen suddenly goes almost black and white?
Hi Evan
Essentially it's a computer inside a modern Flat Screen TV these days. Not a lot that the average person can do...
But... if you feel capable of opening the back....
Once you get inside and check for loose or poor connectors,
I would be looking for leaky Electrolytic Capacitors.
Usually in the power supply section.
Look for brown fluid leaks on PCB & a very slightly puffed out or bowed top on the cap. (ready to explode)
Take a picture of suspect. Take note of Polarity (black stripe) & write down uf & voltage & temp values.
eg 1000uF @ 25v
To prove you are on the right track, you can connect a similar rated Cap across (in parallel) the existing Cap.
Depending on space etc. Even by short extension wires.
Power up & see results. Fault Gone or Not?
Then...
Unsolder & Remove suspect Cap & try to replace with higher voltage rating & slightly higher uf capacity depending on space available around the components.
Good Luck
See
How to Replace an Electrolytic Capacitor
Oct 30, 2015 | Vizio L37 Television
Power supply clicking, turning screen on and off
even though the capacitor looks ok doesn't mean such. I would suggest having the capacitors tested.
Mar 01, 2014 | Samsung SyncMaster Televison & Video
Black screen with sound
You Tv have problem with the backlight inverter board. This type of complaint can occur under two circumstances.
1.Faulty electrolytic capacitor in the power supply board
2. The back light inverter board.
If you have knowledge in electronics then check the power supply for any faulty or budged electrolytic capacitor. Have adde the picture of faulty electrolytic capacitor how it will look like. check the link. faulty capacitor .
If the are no such faulty electrolytic capacitor then you have to replace the back light inverter board. There is no repair possible with inverter board because its spares are rarely available.
You have didn't mention any model number of your tv. so its not possible to add the exact picture of the inverter board.
Ok
Feb 19, 2012 | Sanyo Televison & Video
Ltd pc monitor
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Jun 12, 2010 | ViewSonic Q22WB 22" LCD Monitor
Primare A30.2 power amp has stopped working. Mains fuses are ok. Green light remains flashing - & amplifier inactive - even after normal warm up period (approx 10 seconds) when it would normally show a...
Hi...
It sounds like you have an output amp failure and it looks like you paid good money for it.
If it's under warranty, find a service place. If not let me know your location and I can suggest someone to fix it
Apr 02, 2010 | Audio Players & Recorders
Optiquest Q22wb computer monitor won't come on - power button flashes green then off - power is good. DVI & VGA connected/disconnected - same. Any button diagnostic sequence?
you may have a bad power supply. reon=ve the back cover and look for bad capacitors. crowned or leaking. desolder the bad ones. get new ones from an electronics parts stroe
Dec 25, 2009 | Computers & Internet
Exact Same Problem- Mfr charges 100$ to fix - another way?
Check for bulging capacitors on the DAC (power supply board) replace any that look bad, if all look good replace entire board. should come in under $50
Aug 17, 2009 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
GA-8IHXP won't boot... VER 3.0
The next thing I would check is a close inspection of all the bad capacitors on the board. If you need an idea of what they look like check here.
May 23, 2009 | Gigabyte GA-8IHXP Motherboard
Black out screen dell inspiron 6400
Try to turn on the system with the charger plugged in and also how old is the system.if the system less than a year then try to get the battery changed and may be the motherboard.
Sep 07, 2008 | Dell Inspiron 6400 Notebook
ViewSonic Q22WB 22" LCD Monitor Logo
182 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
