Question about Garmin GPS
Garmin 545s does not turn on, Cable and fuse have been checked and are good.
2 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: MY Garmin NUVI 750 WILL NOT TURN ON EVEN WHEN PLUGGED IN
Have you tried resetting the unit? The procedure can be located here:
http://www.sharc.net/discus/messages/6/313.html?1262532946
- Jim
Posted on Jan 15, 2010
My garmin 545s does not turn on
My Garmin 545s would not power up. I took the unit to West Marine, where they had the correct cable to hook it up and test it. The unit immediately powered up and I purchased a $22 cable and installed it. Easiest test and fix I could come up with. Really cheap fix.
Sep 25, 2013 | Garmin GPSMAP 545s GPS Receiver
Tip
How to Download your Garmin GPSMAP 545 / 545s Users Guide
Have you lost your User's Manual for your Garmin GPSMAP 545 or 545s?
Would you like a digital copy for easy searching of terms and quick reference?
The GPSMAP 545 owner's manual is available from Garmin here.
I hope that helps.
on Jan 31, 2010 | Garmin GPSMAP 545s GPS Receiver
Tip
How to Upgrade and Fix your Garmin GPSMAP 545s System Software
Does your Garmin GPSMAP 545s freeze up?
Is the screen stuck, or do you loose satellite coverage?
I recommend upgrading the system software of your Garmin 545s. There may not be physical damage to your unit, and it may be completely revitalized by replacing the GPSMAP software with the latest version 5.30 (as of January 7, 2010).
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
  5. Load the SD card into your GPSMAP 545s and turn it on to replace the system software of your unit.
I hope that helps.
IS THRER A WAY TO CHECK DC ELECTRICAL SYSTEM ON THE GARMIN545S
Easiest way is to take the unit to West Marine (or wherever they can do it), hook it to their cable, and see what happens. If it operates correctly, a cable is about $22 and in stock. Cheap fix and easy cable install. Call ahead to make sure cable is in stock.
Aug 24, 2012 | Garmin GPSMAP 545s GPS Receiver
Garmin 545s lost gps signal/reads gps error on satilitte page
Lost Satellite Reception - the unit has lost satellite signals. Check
antenna connections or try moving to a location with a clear view of
the sky.
Jan 11, 2012 | Garmin GPSMAP 545s GPS Receiver
My garmin 545 wont turn on. it was working fine and I switched batteries. now it wont turn on
Follow these directions to replace the system software of your Garmin GPSMAP 545s. This should fix it up. It is not uncommon for firmware to become corrupt when switching batteries on some devices.
I hope that helps.
Nov 26, 2009 | Garmin GPSMAP 545s GPS Receiver
I lose satellite coverage on a fairly regular basis. The 545s is mounted in the open.I have only used it twice.
Please review this page for instructions on how to upgrade your units system software. There have been many upgrades for this unit, increasing its accuracy and dependability.
I hope that helps.
Aug 06, 2009 | Garmin GPSMAP 545s GPS Receiver
I tranfert bluechart from my PC using mapsource to
I recommend upgrading your system software to the latest version (5.30),
follow this link for directions and the file's location.
I hope that helps.
Jul 04, 2009 | Garmin GPSMAP 545s GPS Receiver
GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Locating satellite
Initialization time has been greatly reduced with newer system software upgrade for the Garmin GPSMAP 545s. Get your system software upgrade here.
I hope that helps.
Aug 30, 2007 | Garmin GPSMAP 545s GPS Receiver
GPS Logo
46 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
