Question about Slider Lutron: Dual Fan Control / Light Dimmer: 300w, Single Pole
Where can I purchase several Slider Lutron: Dual Fan Control / Light Dimmer little white switches
I have a Lutron Skylark SLV-600p and I want to connect it to control the ceiling fan with light fixture. The chain broke on the ceiling fan and its an old model which the device is inside the light box...
1) It appears this dimmer is not for fan motor.
Dimmer manual says:
"... do not use to control receptacles, fluorescent lighting fixtures, or motor-driven appliances."
http://www.lutron.com/TechnicalDocumentLibrary/030448c.pdf
2) Call Lutron tech support directly:
1-800-523-9466
3) You can replace the pull chain switch to the fan with a bit of dis-assembly and then purchase of new 3-way fan switch at home center. If you decide to do that, add a comment and we can talk details.
4) In order to get a fan-light control to operate from your switch location, you need the following things:
-Fan has to set on high, so unscrew brass part where chain attaches to fan and see if you can grab end of pull chain, and set fan to high.
-Switch box has to be set up to control the light and fan separately. It sounds like your switch box has that capability with a black wire going to light and red wire to fan.
-You need a Lutron combo control that is specifically for controlling ceiling fan, and light fixture.
Call Lutron for best choice.
Last option: 5) Replace fan with new one from home center.
Add a comment if you order the Lutron combo control and I will help you test the wiring and get it hooked up.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via while you work on fan or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 25, 2011 | Garden
We have the slider lutron dual fan control/light dimmer single pole switch and need to install it to work with our fan/light combo which also operates with a remote. How do you install the combo switch? We...
I don't think you can do what you are trying. The fan & light are on one circuit. Probably, originally, there was only a light fixture there. The fan/light is on a single circuit and the remote does the controlling of both units.
Now, you are trying to install a fan control and light dimmer but you don't have wiring for each separately.
You might be able to use one of the dimmer controls to adjust the output to the fan/light combination, but you can't control them individually, if I understand your wiring.
Gary
Dec 19, 2010 | Slider Lutron: Dual Fan Control / Light...
LUTRON SINGLE POLE DIMMER WHEN YOU SLIDE TO THE BRIGHTEST LIGHT AFTER A 15 SECONDS IT DIMS ITSELF BACK TO HALF BRIGHT
Unfortunately, there really isn't a whole lot you can do here to fix it, any attempt you make to strengthen the grip on the slider may gum up something else in the process. Usually they test for this sort of thing before it leaves the factory so I'm actually quite surprised. The best suggestion I can offer is to call their technical support line (they're available 24/7) and they will probably replace the unit for you.
Aug 20, 2010 | Slider Lutron: Dual Fan Control / Light...
Where can I find replacement knobs for the dual slider lutron fan light switches?
I don't think they're a standard off-the-shelf item. But I would call Lutron's tech support center at 1-800-523-9466 - they're available 24/7 and they'll probably just send you some.
Jul 19, 2010 | Slider Lutron: Dual Fan Control / Light...
II have a switch and dimmer and the three wires from fan and light, no instructions how install it.
You will have power coming in through a black wire and white wire on the cable set that does not go out to your fan. The black will connect to your switch to power it. Then there will be two other terminals on your switch one for your fan and one for your light. The red and black that go out to your fan and light are connected to these two terminals. The whites get connected together. If you mix the red and black up and the switches are controlling the the wrong things, simply switch the black and red wires. (Note: If by three wires to your fan you meant black, white and bare copper this dual switch cannot be used, as bare copper is simply a ground wire and cannot be used as a constant electrical conductor.)
Jun 05, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
Dimmer on mains ring
You need a dimmer on a cord, like this:
http://www.homedepot.com/h_d1/N-5yc1vZ1xr5/R-100478442/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Feb 27, 2010 | Slider Lutron: Dual Fan Control / Light...
I need instructions on how to install a 3 way lutron dimmer switch to an exhaust fan motor that will be plugged into an electrical outlet
sorry i don't have what you need but i know that dimmers and fans never work well they always buzz from the lack of power you will actually burn out the brushes in the fan in a short time.
Dec 23, 2009 | Slider Lutron: Dual Fan Control / Light...
Do you have a fan / light switch that can dimm low
I have searched high and low for this. Can't find it. if you find one please let me know...
What I have done in th past is separate the fan and dimming with two devices and if you're in a multi gang box you can combine other switches into a combination unit, or add a side-car box onto the one you already have in the wall...
Oct 11, 2009 | Slider Lutron: Dual Fan Control / Light...
Slider Lutron: Dual  Fan Control / Light Dimmer: 300w, Single Pole Logo
105 people viewed this question
Top Slider Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Slider Electrical Supply Expert? Answer questions, earn points and help others
