Cant call out local or long distance.Phone number dialed want ring.WHY!!!
  • 1,606 Answers
I assume you are talking about using a VOIP device such as vonage to make the calls? There are a fw things that will stop it from working. One is that the setup on the voip unit is wrong. It needs to know the gateway number which is just the ip number of the normal router connected to the cable or dsl modem. It can also be a port setting in your router. To see if this is the problem you can try connecting the voip device directly to the modem. Then try to make a call. If it works then you know it is a port or an ip setting. If it doesn't you could have a faulty voip device or it isn't being authorized by the company.
Posted on Oct 10, 2010
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
Jun 12, 2012 | Brother IntelliFAX 1840C Plain Paper...
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
I can dial local calls and receive local and long distance calls on my GE 27990GE3 but can not dial long distance. After dialing the long distance number I just get a dial tone.
that doesnt sound like a problem with the phone it seems like it is a problem with your provider give them a call they can sort it out good luck
Nov 11, 2010 | GE 27990GE3 Cordless Phone
What do i dial before the long distance number a 1 or a 9
Depending on your phone service. if you pick up the handset and dial a local number without using 1 or a 9 it should be fine. You basically would dial how you would make a call from your phone. Long distance included. If it is a long distance number from your phone, it would be for the fax machine too.
Feb 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
My blackberry dials + when i dial out of my contacts
There is a setting in Phone Options, Smart Dialing, that is enabled by Default. It is Use "1" for National Dialing, and is in place to avoid you needing to dial 1 or edit your Contacts number, if ever you or them are outside of the local area for the number. Basically you do not need to add the 1 if the call is billed as Long Distance. If the contact you are calling is a local number, you will not be charged long distance if the "1" is entered before the number.
Jan 03, 2010 | RIM BlackBerry Pearl 8100
I can fax to local numbers but not to long distance numbers. Phone company has no clue.
Your problem is how you have set up your long distance carrier. You may not be able to use your fax if you must first go through a phone card system. However, sometimes you can use enough pauses in your fax dialing to get through it. If your long distance carrier is your local phone company, they SHOULD be able to tell you how to dial.
Oct 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Panasonic KX-T7630 cannot ring 1800 or 1300 numbers. Telstra can ring 1800 & 1300 numbers by-passing the PABX and plugging straight into the ISDN NT1. Suspected programming problem with system. Please...
Not knowing your complete dialing plan makes it difficult to figure out why you can't "ring" a certain number. What do you get? Can you call local? Is 1800 or 1300 a local or "free" call or is it long distance or premium? And, do you get bounced with a display that says something after you dial 1800 or do you have to dial a complete number.
These are all installer questions. It would be well beyond the scope of a public forum to do someone's restriction tables.
Carl
Sep 04, 2008 | Panasonic KX-T7630 Corded Phone
Long Distance Programing
There is no charge.Most custom features are provided by your local phone provider.Do you have to dial a 0 for an outside line?
tk46
Jul 08, 2008 | NorStar M7310 Corded Phone
No longer dialing Lond Distance
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Apr 04, 2007 | Smartlink (I56KSPF00) Modem
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
