Question about Fisher Paykel EcoSmart GWL15
Error 37 - Fisher Paykel EcoSmart GWL15
  • Fisher Master
  • 713 Answers
Hi Steve.Error code 37 means PUMP BLOCK ERROR.This means your pump is jammed or faulty or your control module is faulty.Please look under the machine for me to the front right.If you have the old style of pump you will see a fan.If there is no fan then you have the new type of pump.Please reply on which pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
Posted on Oct 10, 2010
Error 0x50
This FAQ article may help...
http://www.octoink.co.uk/kb/questions/127/Epson+Error+0x50
Jul 22, 2013 | Epson Business Inkjet B310N Network Color...
I have a Rowe ami R92 jukebox, when I turn it on I get error 37
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Dec 09, 2012 | Audio Players & Recorders
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Hello I have an 8 yo 'Intuitive' with an error message No. 37. Any suggestions as to whats wrong? thanks Pat
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Does your machine drain the water out?Please reply with additional information and I am sure I can help you out.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
Error code 37
37 error is 'pump blocked' It shows when there is little or no change in water level when draining.. It can be caused by a number of problems, but far and away the most common reason is that the pump has something jammed in it! It isn't a big job, but it can be tricky, and the resistance on the pump motor should be checked in case it needs replacing.. A faulty pump can damage the electronics. Empty the machine by baling it out because when the pump is removed any water in the machine will flow from the pump port. A quick job for a tech! Good luck....Nomess
Jun 10, 2010 | Fisher and Paykel GWL11 Top Load Washer
Code 37 on dvd drive
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
1. Open Control Panel and select System.
2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
3. Scroll down the Device Manager window and identify the faulty hardware from the list.
4. Right-click on the hardware and select Update Driver.
5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Aug 04, 2009 | Dell DVD-rom DVD Drive
Error code 37
Hi there
Good luck
Jan 14, 2009 | Computers & Internet
Error -37
Hi, sorry you are having problems,
Well, here is what error -37 is: Code: error -37 bdNamErr Description: Bad file name (File System Error)
Basically, it is saying you cannot save a file by that name in that place....
Did you try saving it elsewhere on your Mac, like on the desktop ?
Just a side note, Apple stopped development on AppleWorks some time ago ( 3 years ) in favour of iWork. I highly recommend getting the newest version of iWork 09, it's compatible with all your Works documents and is really built for MacOS X 10.5, Leopard.
What do you mean whe you say “ Before I reimaged the machine ..” ?
Dec 23, 2008 | AppleWorks 6 for mac
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fisher Paykel EcoSmart GWL15 Logo
447 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
