Trying to replace power plug how does laptop come apart have all screws out cannot get it apart
    Brigadier General:
  • 10,406 Answers
Hmm. Are you sure that you want to go any further,
i.e., I recommend that you STOP and take it to a qualified technician.
The power-plug is soldered to the motherboard;
so, you'll need "good" skills at using a soldering-iron,
if you wish to reattach it.
Did you lift-off and remove the keyboard, taking care to not damage the "ribbon-cables" which connect it to the motherboard?
There could be additional screws under the keyboard.
What manufacturer? What model?
Have you looked at the manufacturer's web-site, for downloadable documents, such as a "Service Manual" for it? That manual would describe the necessary "disassembly" steps.
Posted on Oct 10, 2010
Broken internal power connection on gateway p-631-hsn
I recently repaired one of those with a radioshack plug and socket. If it got bumped somehow, it most likely broke the socket inside. You have to follow all the screw which are marked in length by milimeter. First is getting off the trim around the keyboard which snaps on. This is hard to get apart without breaking. Once you get that, the keyboard should have 2 screws and screws do release everything else, piece by piece. I think I have some pics of the one I did, if I can find them it may help you.
Feb 21, 2013 | Gateway Computers & Internet
I have a GE D52GW12 rear projection tv. It seems to just loose power and turn off at random times. I already tried different outlets to get it working again.I can get it back working if I wiggle the power...
The tv a/c power cord have internal damages short on the head of the a/c plug itself.This work job is pretty simple if u can do a basic soldering jobs and have tools like a soldering iron and a roll of solders.Look around in ur house for a table portable lamp u don't used anymore unsolders and take that portable lamp a/c power cord.It have very simular design and make of a power a/c cord.Take the tv aparts simplely just unsolder the old tv power a/c cord and replace it with a portable table lamp a/c power cord.Those stars srews on the tv are called Allan wrench screws,must a have a set of Allan wrench screws drivers to use take out this screws out of the tv.Some ealier DLP tvs set made by GE are using these Allan wrench screws,tries to make it much more difficult to take the tv aparts as GE they're trying not to allow tvs owner to take the tv aparts.Or have any friend to help u can do it,have a soldering iron,a rolls of solders,have basic soldering skills.A Allen wrench screws drivers set u can buy it anywhere in a hardware store.
Sep 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
My averatec n3400 displays goes dark after 1-2 min the laptop works properly, i can use it with external monitor
Typically the most common problem with back lighting on laptops (especially when it works partially) is the power inverter for the LCD display.
It's a delicate operation but if you're comfortable with taking apart your laptop I would recommend taking apart the LCD cover and try to reseat the power connector to the inverter or simply replace it,
here's an example part I found on google shopping
I've had some success with just reseating the cables, other times I have to replace the inverter.. rarely I have to replace the actual LCD display.
Jun 01, 2011 | Computers & Internet
How do i open my laptop,so i can tighten my power cord input
You will probebly find that it is not a matter of tightening up the dc jack, if it is loose, it is coming away from its housing and you may need to replace the jack.
If you can post the model of the compaq in question i'll try to help further
Feb 12, 2011 | Compaq Computers & Internet
Replace the power in socket on lifebook c1020
i took apart a dell and was having the same problem. on mine it turned out to be double sided tape and it pulled right apart. but you should check, check and recheck for screws before you just yank it apart
Apr 28, 2010 | Fujitsu Lifebook C1020 Notebook
I have removed all the screws from my Evesham W730-K8 laptop because i need to get to the power socket inside, but the laptop still won't come apart. What am I missing?
The best rule to remember is do not force it apart if it does not come apart easy then look for a hidden screw the case does have snap locks on the sides try starting at a point that you can get your fingernail into and slowly move the part that is not coming apart apply a little force but make sure that all screws have been removed you may have to remove some of the thin plastic covers and the battery to make sure all of the screws have been removed
Jun 06, 2009 | Computers & Internet
The connection where you plug in the power on my compact presario R3000 laptop is broken. The female part that you plug into is loose and probably broken away from the solder on the mother board it self. I...
Before you pull apart your laptop, check the male connector and power cord of the adapter, check it with a multimeter and or plug it into another Compaq. You could have a broken wire in the power cord, it could save you a lot of work.
To pull apart the laptop, remove the battery, hard drive and CD drive first.
Then remove all the screws from the bottom of the laptop, plus the screws on the back that holds the LCD's hinge to the laptop base.
Take a note of where the screws come from, some may be shorter that others.
The remove the keyboard (the screws should already been removed from the bottom of the laptop).
Carefully remove the plastic cover next to the base of the LCD screen, This may also cover the hinges, if necessary fold the screen flat to enable you to carefully pry this cover up and off.
The plastic top cover is clip fastened to the bottom of the case, carefully prize apart from one side and gradually work around the other sides.
You can now remove the LCD, there are two connects attached to the motherboard, unclip these.
The motherboard is under the keyboard and plastic top cover, there are screws securing it to the plastic base, remove these and you should be able to free it from the base.
Now you can solder/fix the power connector.
I suggest you use a temperature controlled soldering iron.
Don't use too much force, you might crack the plastic parts.
Best of luck and have fun.
Jan 12, 2009 | Computers & Internet
GATEWAY ta6 WAS DROPPED ON THE CONNECTION FOR THE EXTERNAL POWER SUPPLY (ac adaptar) AND IT MADE THE PIN LOOSE ON THE LAPTOP. I WOULD LIKE TO TAKE THE COVER OFF AND REPAIR THE PRINTED CIRCUIT BOARD AND PIN...
Try here - detailed photos for same problem on different model Gateway:
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Dec 11, 2008 | Computers & Internet
Will not power on wont charge it wont do anything
If the outlet is good and the cord is giving power out - It must be dead. That is all anyone can tell you with what you have stated.
Unless the power plug on the laptop has broken loose.
Sounds like your power plug has come desoldered. This is internal and will have to be taken apart to repair. If you are comfortable with taking it apart you can repair it yourself. If you have not ever soldered anything before or taken a laptop apart before you need to have someone else do it.
If you decide to do it yourself you will need the instruction manual to locate all of the screws. You will need a soldering iron and a camera along with a pencil and paper to draw a diagram and take notes. Laptops have a lot of fragile parts in them that will break. Do not do this if you do not know how. This is something that a qualified tech should do. You will see the plug and you will need to re-solder it back onto the board. One wrong move and you could damage the entire computer. If you try to do this yourself you are on your own and I am not responsible nor is anyone else.
May 29, 2008 | Acer Aspire 3000 Notebook
Lap top computer power problem
Screws, if overtightened or replaced with the incorrect size (i.e., too long a screw), can somtimes cause a board to short. Try taking the screws out completely and then see what happens. It's also possible your laptop may have a bad power supply as a result of the case having been taken apart or put together incompletely. If the first step doesn't work have it diagnosed by a competent repair person . Also, you may consider trying one of eBay's "laptop power" repair services postings. Some offer to replace your power supply fitting (rear plug) for about $50 plus shipping.
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
