Question about Zebra TLP 2844-Z Thermal Label Printer
TLP2844 HI , i'm using a tlp2844 , but now the status light is constantly orange and i don't know what to do . the printer self test is ok and after that the status light make orange would you please help me ? Tnx. Arash
  • 300 Answers
Constant amber means -
1. The cover open sensor is active. Press top cover to close
and lock.
or
2. Printer has a syntax or command error. Check program
and resend print job.
Hope this helps
Posted on Jun 02, 2008
TLP 2844-Z Thermal Label Printer: can the tlp2844 be programmed with zpl?...
If you have an Eltron version, it can't be reprogrammed to support ZPL. It will require replacement of the Main Logic PCB = expensive
May 03, 2010 | Office Equipment & Supplies
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844
TLP2844 does not support Line mode.
but the LP2844 does.
If you neeed to use line mode change your printer. from TLP2844 to LP2844.
I had this issue last week.
Jan 20, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2844 print output very light
The problem was the power adapter appeared to be not original, instead of the required 20V this one produces 15V, found the original power adapter and the printout looks fine, darkness looks ok now.
Regards,
Edwin van Hek
Oct 14, 2008 | Zebra tlp2844ps Thermal Label Printer
TLP2844 won't print
Hi David,
Default the printer so you have a green light.
Print a configuration label so you have the printer's settings.
Check the document you are trying to print.
If your "normal document" is using PCL, it won't print because you aren't speaking the printer's language.
Make sure you are using a Zebra driver and that the label/media settings match your printer. Look at your direct thermal/thermal transfer setting and your media length setting -- especially continuous vs. non-continuous.
Sep 21, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
PDF command for TLP2844
could you give me more info plz
May 22, 2008 | Computers & Internet
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844-Z Thermal Label Printer Logo
439 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
