Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
I plug the power cord and both trays begin to light up and there's no way to stop except by disconnecting the poser
  • KitchenAid Master
  • 43,501 Answers
It seems as though your control board has went bad...
I would do some checking with and electric meter to confirm that and then replace the board...
That is not that hard to fix and you can easily buy the partsyourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Oct 10, 2010
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
Flashing standby light
Flashing red light can sometimes be fixed by holding down the power button on TV until it stops flashing then turn it off then on again. Disconnect everything except power cord before trying this. Mine was fixed this way and saved $500+ repair. Still going over 6 months on. Worth trying.
Apr 08, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My HP C4280 makes a loud clicking noise before it begins to print
Try perform these steps as --->
Please perform these steps as please disconnect the power cable and press the power key for 30 seconds and at the same time connect the power cable then turn on the printer and let me know the status
And also perform this steps as 1. Disconnect and then reconnect the power cord.
2. When the lights begin to flash, press and hold On and Copies button.
When only the On light is flashing, release the buttons.
When the On light is steady, 1. Disconnect and then reconnect the power cord.
When the On light is steady, the reset is complete. the reset is complete.
If the printer works then good
Otherwise Hardware issue
Jul 30, 2010 | HP Photosmart C4280 All-in-One InkJet...
Offline
Ok, if there are NO light, then the Poser Supply, may be faulty, or disconnected. Please Check, Wall Unit?, Plugged in? Turned On? at printer too. Try another cord, socket, if all these still do not get power restored, then you have a problem with the printer, most likely the PS, if it is an external supply, you need to check, that has Voltage coming out. OR replace it with a known good one and check, if it still doesn't work, with a know good PSA, then the printer is faulty.
Apr 14, 2010 | HP PSC 1315 All-In-One InkJet Printer
When I plug in my power cord to my inspiron 1525 it will not charge. The cord appears to be in good shape. What can I do?
check the output of the poser supply. You have power going in ... do you have it coming out??
Dec 29, 2009 | Dell Inspiron 1525 Notebook
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
My eee pc 4G surf won't turn on. It started having problems when the power cord was bumped - causing it to immediately shut down. Then it just stopped booting all together. I replaced the power cord and...
Most likely, either the power jack inside the machine (jack itself or solder joints) or the plug on the power cord was damaged; obviously the plug is only a few dollars to replace, the jack also only a few dollars, but much more labor intensive. My experience tells me it's probably the power jack. If you have any way to externally charge your battery and, using it, find the machine operational, that pins it down pretty well. When the external supply is used, the internal battery is supposed to be switched out of the load circuit and into charging mode.
Aug 06, 2009 | ASUS Eee 4G Notebook
Asus Motherboard Constant High POST beep
long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Aug 01, 2008 | ASUS P4S800-MX Motherboard
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
49 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
