Question about GE Microwave Ovens
Placed a mug of coffee in the microwave and pressed beverage.....the glass plate was not in the microwave at the time....now the microwave is not heating anything
  • radtke777 Oct 13, 2010
    This is the information I am looking for.
    Either I could be told I could fix it or it wasn't worth fixing.
    Thank you...great information.
Your magnatron has failed. This is the component that produces the microwaves that heat the food.
The cost of the magnetron is about 90% of the total cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart and find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. Easier and cheaper to replace it
Posted on Oct 10, 2010
  • GE Master
  • 43,501 Answers
Hi, That events are purely circumstantial.... what you did had no effect on why it is not heating now...it just happened to stop then...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
Sep 24, 2014 | Kenmore Microwave Ovens
Microwave worked this morning and now not.....made no noise just stopped heating.
HELLO.
The solution is to diagnose the magnetron as explained below.
* 1 Fill a mug with room temperature water from your kitchen sink.
* 2 Place the mug of water on the glass cooking plate inside the microwave.
* 3 Set the microwave on "High" for one minute and press "Start." You should hear the magnetron hum while it is working.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. The next step repair or a replacement of magnetron if the water is still cold.
Thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Magnitron does not go on unless i run the vent fan
HELLO.
The solution is to test the magnetron as explain below.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. Contact the manufacturer for repair or a replacement oven if the water is still cold.
Thanks
Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Microwave Ovens
I have B30 Mini Keurig. The green power light comes on but the blue flashing light never comes on after I put the kcup and water in there. It does not brew. What could be wrong?
I also just had the same problem- the answer for me was the coffee mug. The sensor lights where you place your mug don't like certain coffee cups- in my case it was any clear mugs. First I had a clear acrylic coffee mug, then a clear glass mug, then tried regular opaque coffee mugs and it worked fine. So maybe if it's clear or somewhat transparent it might mess up the sensors. Hope that's all the problem is for you.
Aug 29, 2010 | Microwave Ovens
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
Exploded a musical mug in spacemaker xl1800 microwave.
If there's no damage it should be fine.
I would double-check for cracks, especially in the inner door glass and the screen / mesh.
If it looks fine, heat a cup of water in a microwave-safe container for about 2 minutes and see if it cooks without arcing or odd noises and that it boils in about 2 minutes.
As always, never leave a microwave unattended while running.
Jan 28, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave Heating Handle more than Contents
This is because the mugs are not really microwave safe.
For a while they will work, but over time, some non-safe materials' characteristics can change with repeated heating.
Eventually someone will get a burn, and/or a mug will mildly explode into a few pieces.
I have personal and professional experience with this! *grin*
Aug 18, 2008 | Microwave Ovens
Microwave Ovens Logo
244 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
